Solve Problem: Arrow Shot Horizontally Hitting Target 25m Away
  • Thread starter Thread starter mystry4
The problem involves calculating the time it takes for an arrow shot horizontally at a speed of 100 m/s to hit a target 25 meters away. The correct formulas used are dhorizontal = Vo * t and dvertical = 1/2 * a * t^2, where a is the acceleration due to gravity (9.81 m/s²). By substituting the values, it is determined that the arrow reaches the target in 0.25 seconds and impacts 0.30625 meters below the bullseye. These calculations assume no air resistance and that the arrow is shot from ground level.
  • Understanding of basic physics concepts, specifically projectile motion.
  • Familiarity with the equations of motion.
  • Knowledge of gravitational acceleration (9.81 m/s²).
  • Ability to manipulate algebraic equations to solve for unknowns.
  • Study the effects of air resistance on projectile motion.
  • Learn about the impact of initial height on projectile trajectories.
  • Explore advanced projectile motion simulations using tools like PhET Interactive Simulations.
  • Investigate real-world applications of projectile motion in sports and engineering.
Physics students, educators, and anyone interested in understanding the dynamics of projectile motion and its applications in real-world scenarios.
mystry4
I need to make sure I am using the correct formulas (dvertical = 1/2at^2 solving for t^2 and dhorizontal = volt) for the following problem:
arrow shot horizontally - speed of 100m/s - at bullseye 25 m away. How long til it reaches target and where will it hit target.
Thanks! :confused:
Yes, if the arrow is shot horizontally, those are the correct equations. Set dhorizontal= 25 m, a= -9.81 m/s2, and Vo= 100 m/s. Solve the dhorizontal equation for t (how long till it reaches the target) and then use that value to solve for dvertical (where will it hit the target).
To solve this problem, we can use the equations of motion to determine the time it takes for the arrow to reach the target and where it will hit the target.
First, let's define our variables:
- dvertical: vertical displacement (in this case, it is 0 since the arrow is shot horizontally)
- dhorizontal: horizontal displacement (25 m)
- a: acceleration due to gravity (9.8 m/s^2)
- t: time (what we are trying to find)
- Vo: initial velocity (100 m/s)
Using the equation dhorizontal = volt, we can rearrange it to solve for t:
t = dhorizontal / Vo
Substituting our values, we get:
t = 25 m / 100 m/s = 0.25 s
So it will take 0.25 seconds for the arrow to reach the target.
To find where it will hit the target, we can use the equation dvertical = 1/2at^2 and solve for dvertical:
dvertical = 1/2 * 9.8 m/s^2 * (0.25 s)^2 = 0.30625 m
Therefore, the arrow will hit the target 0.30625 meters below the bullseye.
Just a note, we assumed that the arrow was shot at ground level and there is no air resistance. If we take into account the height at which the arrow is shot and air resistance, the calculations may be slightly different. But for this problem, these equations should give a reasonable estimate.
