Particle Motion on a Sphere: Angle of Separation & Geometrical Conditions
  • Thread starter Thread starter abercrombiems02
    Particle Sphere
The discussion revolves around a particle's motion on a sphere of radius R, specifically focusing on the conditions under which the particle separates from the sphere after being disturbed from its equilibrium position. Participants explore the forces acting on the particle and the geometrical conditions influencing its motion.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation, Assumption checking
  • Participants discuss applying Newton's second law to analyze the forces acting on the particle as it slides down the sphere. There are attempts to derive equations of motion and conditions for maintaining contact with the sphere. Questions arise regarding the correctness of the equations and the methods used for solving them.
Some participants have provided hints and guidance on how to approach the problem, suggesting a focus on forces rather than geometry. There is an acknowledgment of the potential for both analytical and numerical solutions, with some expressing confusion over their calculations while others seem to find clarity through discussion.
Participants mention specific assumptions, such as the absence of friction and the use of a particular radius for calculations. There is also a reference to the challenges of working late at night, which may affect problem-solving clarity.
abercrombiems02
Imagine we have a particle sitting on top of a sphere of radius R. The sphere is inertially fixed. A small disturbance force sets the particle in motion from its unstable equilibrium point atop the sphere. Theta is measured from the vertical to the position of the particle. Assume this angle is formed from the center of the circle. At what angle will the particle separate from the sphere? I really can't think of a geometrical condition that must be true for this problem. I've determined the velocity as a function of theta, assuming the only forces are the normal and weight (no friction - the sphere is smooth).
Perhaps this occurs when the horizontal component of the velocity is greater than the rate of change of the sphere's curvature in the x direction?
Any hints, ideas? Thanks
Think in terms of forces, not geometry. Apply Newton's 2nd law to the particle as it slides down the sphere. Realize that for the particle to maintain contact with the sphere it must centripetally accelerate, and the only force available to provide such acceleration is the radial component of the particle's weight. At some point the particle will be going too fast to maintain contact. (Hint: Find the point where the normal force just equals zero.)
Hmmm, I seem to be having some trouble finding a soltuion. If i define u_r to be radially outward, and u_theta, to be tangential to the circle I obtain the follwoing EOMS.
N - mgcos(theta) = -m*omega^2*r (u_r equation)
mgsin(theta) = m*omega_dot*r (u_theta equation)
The condition that when the two separate is when N = 0, so I have the set of equations
g/r*cos(theta)=(d_theta/dt)^2
g/r*sin(theta) = d2_theta/dt^2
I tried solving the bottom one in simulink. Its actually quite a simple model. I just let r = 9.8 m so that the ratio g/r = 1 s^-2. Then I plotted
g/r*cos(theta)-(d_theta/dt)^2 as a function theta. (This is the equation for the normal force), however it never is zero.
Are my EOM's incorrect? I believe I did the dynamics of this problem correctly...
nevermind, thank you. I'm an idiot, had my parathesis around the omega term so it was like (-yout(:,2)).^2... So as you can see the negative sign in that term will be real useful... I get a reasonable answer of 48 degrees with the model and seeing with the assumption of having a radius of 9.8 m, I guess this seems reasonable. Thanks for the hint!
BTW, is there an analytical solution to the set of equations, or is the only way to solve them using numerical methods such as all the built in junk in MATLAB?
You don't need numerical methods--or special assumptions--to solve this problem!
That's one equation that you need, but I'll rewrite it in terms of tangential speed instead of omega (taking N = 0 as the condition for breaking contact):
[tex]mg \cos \theta = m v^2 / r[/tex]
Combine this with an expression for speed (or kinetic energy) as a function of theta (use conservation of energy) and you'll get a simple analytical solution.
wow, that was easy, I got to stop starting this stuff at 1 AM when my mind decides it doesn't want to think anymore. Thanks!
  • · Replies 97 ·
  • · Replies 32 ·
  • · Replies 19 ·
  • · Replies 59 ·
