Calculating Cumulative Effect of Slowing Earth's Rotation Over 20 Centuries
  • Thread starter Thread starter NYmike
    Rotation
The discussion revolves around a physics problem concerning the cumulative effect of the Earth's slowing rotation over 20 centuries, specifically how this affects the measurement of time. The original poster expresses confusion about the problem's wording and the calculations involved.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants explore different methods to calculate the cumulative time added due to the gradual increase in the length of a day. Some suggest a direct summation approach, while others propose using integration to account for the continuous nature of the change. Questions arise regarding the implications of the term "continuously" and how it affects the calculations.
There are multiple interpretations being explored, with some participants providing guidance on how to approach the problem using both summation and integration methods. The discussion reflects a productive exchange of ideas without reaching a consensus on a single method.
Participants note the assumption of disregarding fractional days and the need to clarify the meaning of "continuously" in the context of the problem. There is also mention of potential factors that could affect the calculations, such as the number of days in a century.
NYmike
Hello. I am stuck on this physics problem that i have for homework. Its the wording of the question that's odd to me. I am not sure exactly where to begin.
Assuming the length of the day uniformly increases by 0.001 sec. per century, calculate the cumulative effect on the measure of time over 20 centuries. Such slowing of the Earth's rotation is indicated by observations of the occurrences of solar eclipses during this period.
So after one century, the length of each day will be 24 hours and .001 s? And after the second century the length of each day will be 24 hours and .002 s? Is there a quicker way to do this than doing a 20-step summation!?? I started off by multiplying .001 x 365, because that will give you the total amount of added time after a year ... however after that it would be long summation, and I am sure that there must be a quicker way.
(FYI, the answer is 2 hours if you want to check your work :P)
thanks in advance for any help/leads.
One thing that worries me is the word continously, but disregarding that you are on the right track. But you will be off by a factor of 100.
So you have 100 years in every century with 365 days in every year (we are disregarding the fractional day here).
[tex]36500 \times .001 + 36500 \times .002 + 36500 \times .003 \ldots 36500 \times .019[/tex]
notice it only goes up to .019 since the first year has no additional time.
This is then equal to:
[tex]36500 \times (.001 + .002 + .003 \ldots .019)[/tex]
Then divide this number by 3600 (the number of seconds in an hour) and you should get the correct answer.
The proper way to do this is by integration since the change is continuous.
Let the length of a day in seconds D be a continuous function of time t. D(t) is linear. The number of days in a century is about 365.25*100 = dc. So if the length of the day at t=0 is 24*3600, after dc days D = 24*3600+.001. The slope of the graph of D(t) vs. t is:
[tex]\frac{D(dc)- D(0)}{dc}[/tex] so:
[tex]D(t) = D(0) + \frac{D(dc)- D(0)}{dc}t[/tex]
Integrating D(t) from 0 to 20 centuries gives us the length (L(t)) in days:
[tex]L(t) = \int_0^t (D(0) + \frac{D(dc)- D(0)}{dc}t) dt[/tex]
[tex]L(t) = D(0)t + \frac{D(dc)- D(0)}{2dc}t^2[/tex]
[tex]L(20dc) = D(0)(20dc) + \frac{D(dc)- D(0)}{2dc}(20dc)^2[/tex]
If you work that out and subtract D(0)*20dc (the measured time), you will get the difference between actual accumulated time and measured time.
eg.
[tex]L(20dc) = D(0)(20dc) + \frac{.001}{2dc}(20dc)^2[/tex]
[tex]L(20dc) = D(0)(20dc) + .001(200dc)[/tex]
[tex]L(20dc) - D(0)(20dc) = 7305[/tex]
So the difference is 7305 seconds or just over 2 hours.
AM
Edit: My earlier post used seconds rather than days.
Yeah, I realized that this is quite easy once you look at it this way:
[tex]36500 \times (.001 + .002 + .003 \ldots .020) = 36500 \times 10^{-3} \times \sum_{x=0}^{20} x \rightarrow 36500 \times 10^{-3} \int_0^{20} x dx[/tex]
all we are doing here is going from the discrete sum to the continuous integration (I know, I know this is not mathematically rigorous, I left out the limiting procedure, but hey, I am a physicist)
You get the same answer as Andrew.
11K
9K
29K
