What is the distance of the image?
  • Thread starter Thread starter brayrbob
The distance of the image formed by a converging mirror with a focal length of 5.5 cm and an object located 19.5 cm away is calculated to be 7.66 cm. This image is real and inverted, as it is located beyond the focal point. The magnification can be determined using the formula magnification = Di/Do, where Di is the image distance and Do is the object distance. The discussion confirms the correct application of the mirror equation and the characteristics of the image formed.
  • Understanding of the mirror equation: 1/object-mirror distance + 1/image-mirror distance = 1/mirror's focal length
  • Knowledge of image characteristics (real vs. virtual, upright vs. inverted)
  • Familiarity with magnification calculations
  • Basic principles of optics related to converging mirrors
  • Study the mirror equation in detail, including derivations and applications
  • Learn about the characteristics of images formed by different types of mirrors
  • Explore magnification concepts and how they apply to various optical systems
  • Investigate the behavior of virtual images and their formation in optical devices
Students of physics, educators teaching optics, and anyone interested in understanding the principles of image formation by mirrors.
brayrbob
An object is located 19.5 cm from a converging mirror with a focal length of 5.5 cm. What is the distance of the image? Is it real or virtual? Is it smaller or larger than the object? Is it upright or inverted?
This is the equation I need to use for the problem
1/object-mirror distance + 1/image-mirror distance= 1/mirror"s focal lenth to solve for image-mirror distance
This is how I solved for the problem
1/image-mirror distance = 1/5.5 - 1/19.5 = .1305361305 then I have to find the reciprocal which is 1/.1305361305 = 7.660714288 or 7.66cm
Have I solved this correctly?
It's farther than the focal point, which immediately tells you that it's real and inverted.
but i believe you have solved correctly
remember, magnification is Di/Do
Okay, then when it's closer than the focal point, does that mean that it's virtual and upright?
  • · Replies 16 ·
