Analyzing Critical Points of a Multivariable Function
The discussion focuses on analyzing the critical points of the multivariable function f(x,y) = a*x^n + c*y^n, where n ≥ 2 and a*c ≠ 0. The only critical point identified is (0,0), but the Hessian matrix's determinant is zero, rendering the second derivative test inconclusive. The analysis suggests that if ac > 0 and n is even, the critical point is a minimum or maximum based on the signs of a and c. Conversely, if ac < 0 and n is even, the critical point is a saddle point. Alternative methods such as evaluating the function near (0,0) or analyzing behavior along different paths are recommended for further insights.
  • Understanding of multivariable calculus
  • Familiarity with critical points and their significance
  • Knowledge of the Hessian matrix and second derivative test
  • Ability to analyze polynomial functions
  • Explore the properties of the Hessian matrix in detail
  • Learn about the second derivative test for multivariable functions
  • Investigate the behavior of functions near critical points through plotting
  • Study the concept of saddle points in multivariable calculus
Mathematicians, students of calculus, and anyone involved in analyzing multivariable functions and their critical points.
pbialos
Given [tex]n\geq 2, n\in \aleph[/tex] and [tex]f(x,y)=a*x^n+c*y^n[/tex] where [tex]a*c\not=0[/tex], determine the nature of the critical points. I found the only critical point at (0,0) and when i tried to use the criteria of the determinant of the hessian matrix to determine the kind of critical point it was, it gave me 0, so i can`t say nothing by this criteria.
I don't know what kind of analysis of the function i am supposed to do, so any help would be much appreciated.
Many Thanks, Paul.
You can say something of the critical points. First, consider the options ac < 0 and ac > 0. If ac > 0, then you just have polynomials that are just positive multiples of each other. If the polynomial is of odd order, you have nothing (think f(x) = x³), and if it is of even order, then you have a minimum if a > 0 (and hence c > 0) or a maximum if a < 0 (and hence c < 0). Now if ac < 0, then if n is odd, then you again have nothing since this is the same if n is odd and ac > 0, just rotated by 90o. If n is even, then you'll have a saddle point of type (1-1) and unlike minima and maxima, an upside down saddle point is still a saddle point (whereas a maximum becomes a minimum).
The analysis of critical points for a multivariable function involves determining the points where the partial derivatives of the function are equal to zero. In this case, the only critical point is (0,0) since both partial derivatives of f(x,y) with respect to x and y are equal to zero.
To determine the nature of this critical point, we can use the second derivative test or the Hessian matrix. However, in this case, the Hessian matrix is not helpful since its determinant is equal to zero. This means that the second derivative test does not provide any information about the nature of the critical point.
In order to further analyze the critical point at (0,0), we can look at the behavior of the function around this point. We can do this by plotting the function or by evaluating the function at points close to (0,0). This will help us determine if the critical point is a local maximum, local minimum, or a saddle point.
Additionally, we can also consider the behavior of the function along different paths approaching the critical point. This can give us a better understanding of the behavior of the function at this point.
In conclusion, while the Hessian matrix may not provide any information about the nature of the critical point, there are other methods we can use to analyze the function and determine the nature of the critical point at (0,0).
  • · Replies 27 ·
