Figuring Out Total Kinetic Energy of Rotating Object
  • Thread starter Thread starter marcia888
    Formula
The total kinetic energy of a rotating object is calculated using the formula K total = K translational + K rotational, represented as K total = \frac{1}{2}mv^2 + \frac{1}{2}I (\frac{v}{r})^2. The alternate formula K total = \frac{1}{2}mv^2(1+\frac{I}{mr^2}) is derived by factoring and substituting the moment of inertia (I) into the original equation. This derivation involves rearranging terms and recognizing that I can be expressed as mr^2 for a point mass. The alternate formula effectively combines both translational and rotational kinetic energies for comprehensive calculations.
  • Understanding of kinetic energy concepts
  • Familiarity with moment of inertia (I)
  • Basic algebraic manipulation skills
  • Knowledge of rotational motion principles
  • Study the derivation of moment of inertia for various shapes
  • Learn about the relationship between linear and angular velocity
  • Explore applications of kinetic energy in rotational dynamics
  • Investigate energy conservation in rotating systems
Physics students, mechanical engineers, and anyone interested in the principles of rotational dynamics and energy calculations.
marcia888
This isn't a homework question, but I'm just wondering how the text in the book gets from one formula to the next.
To figure out total kinetic energy of a rotating object:
[tex]\frac{1}{2}mv^2+\frac{1}{2}I (\frac{v}{r})^2[/tex]
Then the book gives an alternate formula:
[tex]\frac{1}{2}mv^2(1+\frac{I}{mr^2})[/tex]
So I wanted to see how they get from one to the other. So I tried
factor out the 1/2v^2
[tex]\frac{1}{2}v^2 (m+\frac{I}{r^2})[/tex]
almost there. But how do I get a 1 in place of the m? I could divide by m, but then I get
[tex]\frac{v^2}{2m} (1+\frac{I}{mr^2})[/tex]
It works for the right term, but not the left. What am I doing wrong?
You just didn't factor out completely.
You ended up with,
now take out m. i.e. divide both terms inside the brackets by m so that you end up with m outside the barckets.
Alternatively, you could multiply out the alternate formula, and you will end up with the original one.
The alternate formula for calculating total kinetic energy of a rotating object is derived from the original formula by substituting the moment of inertia (I) for the rotational kinetic energy term (\frac{1}{2}I (\frac{v}{r})^2). This can be seen by rearranging the original formula as follows:
K translational + K rotational = \frac{1}{2}mv^2+\frac{1}{2}I (\frac{v}{r})^2
= \frac{1}{2}mv^2+\frac{1}{2}(\frac{I}{r^2})v^2
= (\frac{1}{2}m+\frac{1}{2}(\frac{I}{r^2}))v^2
= (\frac{1}{2}m+\frac{I}{2r^2})v^2
Since the moment of inertia (I) is equal to mr^2 for a point mass rotating around a fixed axis, we can substitute this in the formula:
= (\frac{1}{2}m+\frac{mr^2}{2r^2})v^2
= (\frac{1}{2}m+ \frac{m}{2})v^2
= (\frac{m}{2}+\frac{m}{2})v^2
= mv^2
Thus, the alternate formula can be written as:
which simplifies to:
K total = \frac{1}{2}mv^2(\frac{m+mr^2}{m})
This alternate formula is useful when calculating the total kinetic energy of a rotating object, as it takes into account both the translational and rotational kinetic energies.
18K
  • · Replies 24 ·
