How to Decode SEND+MORE=MONEY?
  • Thread starter Thread starter aricho
    Numbers
The discussion revolves around the cryptarithm SEND + MORE = MONEY, where participants explore how to assign digits to letters such that the equation holds true. The problem falls under the subject area of algebraic reasoning and number theory.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss the representation of letters as digits and the mathematical expressions that arise from this representation. There are attempts to clarify the structure of the equation and the implications of digit assignments. Some participants express confusion about the reasoning process and seek to understand the steps involved.
The discussion is active, with participants offering insights into the problem and questioning assumptions about the digits represented by the letters. Some have provided alternative solutions, while others are working through the implications of their findings. There is no explicit consensus, but several productive lines of inquiry are being explored.
Participants note constraints such as the requirement that each letter represents a different digit and the implications of the maximum values for SEND and MORE. There is also a focus on the significance of the leading digits in the numbers involved.
aricho
Letters to Numbers?
Hey, I have no idea how to do this...
Replace all the letters with the respective digits in such a way that the calculation is correct
SEND+MORE=MONEY
the answer is 9567+1085=10652, but i don't know how to get there.
Thanks for your help
All right, let us say S, E, N, D, M,R,O, Y stands for different digits s,e,n,d, m,r,o,y between 0 and 9.
Hence, SEND=s*1000+e*100+n*10+d*1
Do you agree to this?
sorry, lost
aricho said:
sorry, lost
Why are you lost now?
Try to formulate what EXACTLY you are struggling with understanding; that's difficult, I know, but the only way to actually start achieving understanding.
i would have thougt it would have been s*1000+e*100+n*10+d
And your thought is perfectly correct and valid!
But, since any number multiplied with 1 equals itself, d=d*1, right?
So that means we agree on our expression after all..
The reason why I put in the *1 notation, is that it is conventional (and systematic) to do so, not because your idea is wrong (which it isn't)!
OK?
This problem have so many solutions to it... I'll give you another one:
9342 + 1093 = 10435. Is that also correct?
Looking thoroughly at that, you will notice: m = 1, o = 0, r = 8 (or 9). The other number can be wisely chosen to fit the SEND + MORE = MONEY.
Viet Dao,
arildno, yes, got it now.
Whats next?
Viet Dao,
WOW, YOU ARE VERY SMART!
IT IS SO GREAT THAT YOU MAKE O.P. A LOT MORE CONFUSED THAN HE ALREADY WAS!
:smile:
Whats next?
Okay, now you can make a similar decomposition into sum expressions of MORE and MONEY as well, right? (Do that!)
Verify therefore that SEND MORE=MONEY can be written as:
(s+m)*1000+(e+o)*100+(n+r)*10+(d+e)*1=m*10000+o*1000+n*100+e*10+y*1
Ok?
:cry: :cry: :cry: Whoops, I thought I will have a chance to explain more when he continues asking questions. I hate reading long, long posts... therefore I just shorten everything. :wink:
Viet Dao,
Viet Dao,
He's all yours now, if you like.
I'm logging off..
Just stay there,... I don't like, anyway. Maybe I can learn a different way from you.
Viet Dao,
yer, kinda...
What do you mean by "kinda"?
Did you get what I was doing , but don't understand why I've done it like that?
sorry, i just wrote it down, agree-got it
All right:
1. Now, you agree that whatever digits the letters represent, each of the numbers SEND and MORE must be less than or equal to 9999, right?
2. But that must mean that their sum must be less than or equal to 9999+9999=19998, agreed?
3. Now, look at the MONEY-side of your equation:
The first term there is m*10000
Thus, if you combine this with the insight you've gained in the above argument, what digit must "m" be if we assume that "m" is different from zero?
If you have problems with this post, please pinpoint what you didn't understand too well.
.....1?
Okay, 9 is the biggest digit we've got, right?
So, the number 9999 must be bigger than any other number with 4 digits, whatever digit a given letter might represent.
Get it?
(I made a writing error in 1., I've fixed it now)
yer....got that
Since 9+ 9= 18, even if we borrowed 1 from the previous column, the largest the left most column sum can be is 19 so m must be 1. Knowing that the m in "more" must be a 1. That means that the s in "send" has to be either 8 or 9 (because even borrowing 1 from the previous column, if s= 7 we would have 7+1+1= 9 and there is no 1 to carry). So far we have
8end 9end
1ore or 1ore
1oney 1oney
  • · Replies 24 ·
  • · Replies 36 ·
  • · Replies 64 ·
