What is the tension in the cable car's cable?
  • Thread starter Thread starter marissa12
    Cable Tension
The discussion revolves around determining the tension in the cable car's cable, specifically in the context of a tensioning pulley system associated with cable cars in San Francisco. The problem involves concepts from mechanics, particularly equilibrium and forces acting on objects.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants explore the forces acting on the tensioning pulley and the attached block, questioning the necessity of certain information, such as the mass of the cable car. There is discussion about the equilibrium condition and the implications for tension in the cables.
The discussion is active, with participants providing hints and prompting each other to consider the equilibrium of forces. Some guidance has been offered regarding the relationship between the forces on the pulley and the block, but no consensus has been reached on the final tension value.
Participants note that the problem may contain extraneous information and are questioning the assumptions regarding equilibrium and the forces involved. The specifics of the cable car's mass and its impact on the tension are also under consideration.
marissa12
The cable cars in San Francisco are pulled along their tracks by an underground steel cable that moves along at 9.5 mph. The cable is driven by large motors at a central power station and extends, via an intricate pulley arrangement, for several miles beneath the city streets. The length of a cable stretches by up to 100 ft during its lifetime. To keep the tension constant, the cable passes around a 1.5-m-diameter "tensioning pulley" that rolls back and forth on rails, as shown in the figure. A 2000 kg block is attached to the tensioning pulley's cart, via a rope and pulley, and is suspended in a deep hole.
i know a lot of the info is unecessary..
but wouldn't you need to know the mass of the cable car? because i think that the tensioning pulley.. just shows that it is in equlibrium so you don't need it.
Consider the horizontal forces acting on the "tensioning pulley". Since it's in equilibrium, what must be the net force on it? Thus what must be the tension in the cables? Hint: What's the tension in the cable attached to the hanging block?
is the Ft in the cable attached to the block:
Ft-fg(2000*9.81)=ma Ft-(2000*9.81)=(2000)(a)
if its in equilib. then the net force is zero.
Yes, the pulley and the block are both in equilibrium, so the net force on each is zero.
What are the forces on the pulley? You have the rope tension pulling to the left. (What is that tension? You didn't finish the calculation that you started, but you were on the right track.) And you have the tension in the cables pulling to the right. Note that the cable has two sections pulling on the pulley (that's the big hint).
15K
