First order coupled differential equations
The discussion revolves around solving a system of first-order coupled differential equations, specifically the equations dx/dt = 5x + 3y and dy/dt = x + 7y, with given initial conditions. Participants explore various methods for finding solutions, including eigenvalue approaches, matrix methods, and alternative formulations.
  • One participant expresses difficulty in understanding the coupled differential equations and seeks guidance on solving them.
  • Another participant confirms the eigenvalues and eigenvectors calculated and proposes a solution format using these values.
  • A different approach is suggested involving diagonalization of the matrix associated with the differential equations, leading to uncoupled equations.
  • Some participants discuss the possibility of converting the system into a second-order differential equation, providing a method for doing so.
  • One participant mentions using Laplace transforms as an alternative method to solve the system, highlighting its advantage in incorporating initial conditions directly into the solution.
  • Multiple participants reiterate the method of substituting one equation into another to derive a second-order ODE, emphasizing its validity.
  • References to textbooks and online resources for further reading on differential equations are provided by some participants.
Participants present multiple competing views on how to approach the solution of the differential equations, with no consensus on a single method being the best. Various methods are discussed, including matrix approaches, second-order formulations, and Laplace transforms.
Some participants note the complexity of the methods discussed, indicating that familiarity with linear algebra and matrix operations is beneficial. There are also mentions of limitations in the clarity of the presented solutions and the need for further elaboration on certain steps.
This discussion may be useful for students and professionals in engineering, mathematics, and physics who are dealing with systems of differential equations and are seeking various methods to solve them.
knish
Hello
I'm struggling with this concept, can't seem to get my head round it or find any good reference sites or books.
I have calculated the eigen values and eigen vectors for the following matrix
5 3
1 7
Eigen values 4, 8
Eigen vectors 4: 3
-1
Eigen vectors 8: 1
Now need to solve these first order coupled differential equations (this is where i just go uhhh?)
dx/dt = 5x + 3y
dy/dt = x + 7y
initial conditions are x(0) = 5 and y(0) = 1
Any help or pointers would be greatly appreciated, my mind has just gone blank.
Thanks Rich (Electronic Engineer - If it aint got wires i can't do it!)
For the system:
[tex]\frac{dx}{dt}=5x+3y[/tex]
[tex]\frac{dy}{dt}=x+7y[/tex]
You determined the eigenvalues and eigenvectors. Thus the solution is:
[tex]\left(\begin{array}{c} x(t) \\y(t)\end{array}\right)=k_1e^{4t}<br /> \left(\begin{array}{c} 3 \\ -1 \end{array}\right)+k_2e^{8t}<br /> \left(\begin{array}{c} 1 \\ 1 \end{array}\right)[/tex]
Right?
Substituting the initial conditions:
[tex]\left(\begin{array}{c} 5 \\ 1 \end{array}\right)=<br /> k_1\left(\begin{array}{c}3 \\ -1 \end{array}\right)+<br /> k_2\left(\begin{array}{c}1 \\ 1 \end{array}\right)[/tex]
Now just figure out what the constants are. You know how to read this matrix stuf huh? That last one is just:
[tex]5=3k_1+k2[/tex]
[tex]1=-k_1+k_2[/tex]
Same dif for reading the other one.
Edit: Oh yea:
Welcome to PF and
"Differential Equations" by Blanchard, Devaney, and Hall is one DE book I use.
If you're comfortable with the linear algebra, you could look at it like this:
You have the (matrix) differential equation x' = Ax.
You diagonalized A, giving [itex]A = P^{-1} D P[/itex].
Since A is constant, you can rewrite the equation as:
[tex]\vec{x}' = A\vec{x} = P^{-1} D P\vec{x}[/tex]
[tex]P\vec{x}' = DP\vec{x}[/tex]
[tex](P\vec{x})' = D (P\vec{x})[/tex]
Which is a pair of uncoupled differential equations in the components of Px, which is easy to solve. Once you know Px, you can compute x.
Actually, if you're comfortable with more advanced matrix manipulations, you can go from x' = Ax directly to [itex]\vec{x}(t) = e^{At} \vec{x}_0[/itex]. Of course, that requires you to know how to compute a matrix exponential. :biggrin: You have to do the same amount of work either way, though.
One other releated question on this, isn't there a way to avoid using matrices and instead represent two coupled first order differential equations as one second order differential equation? I need to start working on a couple problems today and I was advised that would be the best way to attack them. Does anybody know the form for that?
~Lyuokdea
~Lyuokdea
Yes, there is. I wouldn't consider it the "best way" to handle systems of equations but it is simpler and less sophisticated and so perhaps better for a beginner.
saltydog has already pointed out that the d.e.s associated with the matrix given are:
[tex]\frac{dx}{dt}=5x+3y[/tex] and
Differentiate that first equation again with respect to t to get
[tex]\frac{d^2x}{dt^2}= 5\frac{dx}{dt}+ 3\frac{dy}{dt}[/tex]
Replace the [tex]\frac{dy}{dt}[/tex] in that with x+ 7y:
[tex]\frac{d^2x}{dt^2}= 5\frac{dx}{dt}+ 3(x+ 7y)[/tex]
[tex]\frac{d^2x}{dt^2}= 5\frac{dx}{dt}+ 3x+ 21y[/tex]
There is still a "y" in that but from the first equation,
[tex]3y= \frac{dx}{dt}- 5x[/tex] so we have
[tex]\frac{d^2x}{dt^2}= 5\frac{dx}{dt}+ 2x+7(\frac{dx}{dt}- 5x)[/tex]
[tex]\frac{d^2x}{dt^2}= 12\frac{2x}{dt}-32x[/tex].
The characteristic equation for that is [tex]r^2= 12r- 32[/tex] exactly the same as the eivenvalue equation for the original matrix and has, of course, the same roots: 4 and 8.
The general solution for x is: x(t)= C1e4t+ C2e8.
To solve for y use [tex]3y= \frac{dx}{dt}- 5x[/tex]. Notice that you don't have to do any integration to solve that for y so you have the same "C1" and "C2" coefficients in both x and y.
Soooo
That is the acctual soloution?
Thanks for your help
knish said:
Soooo
[tex]5=3k_1+k_2[/tex]
Knish . . . no dude . . . no, no. I'm disappointed you'd think that. Not in you but me for presenting the solution in a way that would make you think that's the solution. That's just the two equations used to figure out what the constants k1 and k2 are. The actual solution is:
[tex]\left(\begin{array}{c} x(t) \\y(t)\end{array}\right)=k_1e^{4t} \left(\begin{array}{c} 3 \\ -1 \end{array}\right)+k_2e^{8t} \left(\begin{array}{c} 1 \\ 1 \end{array}\right)[/tex]
That reads:
[tex]x(t)=3k_1e^{4t}+k_2e^{8t}[/tex]
[tex]y(t)=-k_1e^{4t}+k_2e^{8t}[/tex]
Now, just figure out what k1 and k2 are from the expression:
close to saltydog' solution:
x = y' - 7y
x' = y'' - 7y'
if we put these in x' = 5x + 3y:
y'' - 12y' +32y = 0
now we have second order diff eq. a heuristic solution for y could be
y = exp(r*t)
y' = r * exp(r*t)
y'' = r^2 exp(r*t)
where r is a constant
then,
exp(r*t) {r^2 - 12r + 32} = 0
exp(r*t) cannot be zero unless t or r is minus infinity. therefore r is either 8 or 4. then you can solve the rest I believe.
one last thing: engineering is not about wires, it's technician's work. an engineer without math skills is like a butcher without a knife.
The system given was:
dx/dt = 5x + 3y
dy/dt = x + 7y
Another method of solution which hasn't been mentioned is LaPlace transforms. This method has the advantage of "building in" the initial conditions to the solution. Using L for the LaPlace operator, the equations become:
sL(x) - 5 = 5L(x) + 3L(y)
sL(y) -1 = L(x) + 7L(y)
(5 - s)L(x) + 3L(y) = -5
L(x) + (7-s)L(y) = -1
Easy to solve by determinants for L(x) and L(y). For example, for L(x) you get:
L(x) = (-32 + 5s) / (32 - 12s + s2) = 3/(s-4) + 2 /(s-8)
using partial fractions. So you get
x = 3e4t + 2e8t
and similarly easy for y.
dx/dt = 5x + 3y ---- (1)
dy/dt = x + 7y -----(2)
For simple DEs as above, you can make equation (1) subject of y and substitute into equation (2) to obtain a 2nd order ODE. From there you can solve for x and then y.
That's what I showed in the 5th post.
Some references about ordinary differential equations
If you are interested in some references about solving system of linear differential equations, please refer to the post I have written here:
http://www.voofie.com/content/18/solving-system-of-first-order-linear-differential-equations-with-matrix-exponential-method/"
If you would like to learn more about differential equations, you may refer to my article, which teaches how to solve 1st order, and higher order differential equations:
http://www.voofie.com/content/6/introduction-to-differential-equation-and-solving-linear-differential-equations-using-operator-metho/"
