Calculating Velocity at any given point in an orbit
  • Context: Undergrad
  • Thread starter Thread starter relativitydude
    Orbit Point Velocity
The discussion revolves around calculating the velocity at any given point in an elliptical orbit, focusing on the mathematical formulation of the problem using parametric equations. Participants explore the derivation of velocity from position equations and the implications of parameterization on the results.
  • One participant proposes using parametric equations for an ellipse to derive velocity, suggesting that taking the derivative of position yields velocity components.
  • Another participant confirms the initial velocity expression but later challenges the parameterization, indicating that a more general form should be used to account for varying angular velocity.
  • There is a discussion about substituting original position variables into the velocity equation, with one participant questioning the validity of not substituting the differentiated variables.
  • A later reply suggests that the derived expression for speed can be reformulated in terms of x, using the relationship between x and y derived from the ellipse equation.
  • One participant expresses concern that the initial parameterization does not account for the conservation of angular momentum, suggesting that the angular velocity should not be constant.
Participants express differing views on the appropriateness of the parameterization used for the ellipse and its implications for calculating velocity. There is no consensus on the correct approach, and the discussion remains unresolved regarding the best method to derive velocity in this context.
Limitations include the dependence on the chosen parameterization of the ellipse and the unresolved implications of angular momentum conservation on the velocity calculations.
relativitydude
Hello,
I'm trying to really understand orbits. I want to be able to calculate the velocity at any given point in an orbit.
Now, parametrically an ellipse can be:
x = a*cos(t)
y = b*sin(t)
If those are position, can I take the derivative to obtain velocity?
x' = -a*sin(t)
y' = b*cos(t)
For the overall velocity:
V = sqrt( (-a*sin(t))^2 + (b*cos(t))^2)
However, there is a pesky t in there, now I use:
x' = -a*sin(t)
Solve for t
-x'/a = sin(t)
asin(-x'/a) = t
And subsitute t back into overall equation? Does this make sense or am I just making stuff up?
relativitydude said:
Hello,
x = a*cos(t)
y = b*sin(t)
x' = -a*sin(t)
y' = b*cos(t)
x' = -a*sin(t)
Solve for t
-x'/a = sin(t)
asin(-x'/a) = t
From your equations, you have computed the speed
V = sqrt( (-a*sin(t))^2 + (b*cos(t))^2).
Since
x = a*cos(t)
y = b*sin(t)
then
(x/a) = cos(t)
(y/b) = sin(t).
So,
V = sqrt( (-a*(y/b))^2 + (b*(x/a))^2).
I was going for in only for terms of x, to disclude y
Is it valid how you subsituted the original x and y, but not the differentiated ones?
I believe it's fine.
Continuing on...
(x/a) = cos(t)
(y/b) = sin(t)
means that
(x/a)^2+(y/b)^2=1
which can be solved for (y/b)^2.
That expression can then be inserted in the speed expression I derived, yielding an expression for the speed in terms of x... if that's what you really want.
Hello,
x = a*cos(t)
y = b*sin(t)
x' = -a*sin(t)
y' = b*cos(t)
x' = -a*sin(t)
Solve for t
-x'/a = sin(t)
asin(-x'/a) = t
Your very first step is wrong :-( You've parameterized an ellipse, but it's not the most general possible parameterization, which is
x = a cos(f(t))
y = b sin(f(t))
where f(t) can be any function.
then dx/dt = -a sin(f(t)) df/dt, dy/dt = b cos(f(t)) df/dt
The correct parameterization will sweep out equal areas in equal times (Kepler's law - this conserves angular momentum), so the angular velocity will be inversely proportional to the radius. Your equation has the angular velocity as being constant, which is wrong.
You should be able to work the problem out more simply, by taking advantage of the fact that angular momentum and energy are both conserved.
nicely done my son!
  • · Replies 17 ·
  • · Replies 17 ·
