Maximizing Cannon Range from a Cliff of Height h
The discussion revolves around maximizing the range of a cannonball shot from a cliff of height h, with an initial velocity v_0 and an angle of elevation θ. Participants explore the mathematical relationships governing projectile motion without air resistance, particularly focusing on how to determine the optimal angle θ for maximum range.
  • Mathematical reasoning, Assumption checking, Problem interpretation
  • Participants analyze the trajectory equations and derive expressions for time of flight and range. They discuss the implications of setting the derivative of the range with respect to θ to zero and explore potential simplifications. Questions arise regarding the validity of certain assumptions, particularly concerning the case when h = 0.
The discussion is ongoing, with participants offering insights and questioning the correctness of derived formulas. Some suggest that the original poster's approach may be flawed due to assumptions made about h, while others explore alternative expressions for θ. There is no explicit consensus on the optimal angle yet, but several lines of reasoning are being actively examined.
Participants note the importance of the condition h > 0 in the problem and discuss the implications of allowing h to approach zero. The conversation includes references to specific mathematical expressions and their derivations, indicating a complex interplay of variables that may affect the outcome.
bomba923
I shoot a cannon from a cliff of height [itex]h[/itex], with an initial velocity [itex]v_0[/itex] and angle of elevation [tex]\theta[/tex]. If [itex]h > 0[/itex], what [tex]\theta[/tex] will maximize the cannon's range (how far the cannonball lands from base of the cliff), assuming no air resistance?
Ok...
The cannonball's height at any moment within its trajectory is
[tex]y = h + v_0 t\sin \theta - \frac{{gt^2 }}{2}[/tex]
The cannon will land at ground zero, so I find that the time spent in the air is:
[tex]y = h + v_0 t\sin \theta - \frac{{gt^2 }}{2} = 0 \Rightarrow t = \frac{{v_0 \sin \theta + \sqrt {v_0^2 \sin ^2 \theta + 2gh} }}{g}[/tex]
And therefore the range is:
[tex]x = v_0 \frac{{v_0 \sin \theta + \sqrt {v_0^2 \sin ^2 \theta + 2gh} }}{g} \cos \theta = \frac{{v_0 }}{g}\left( {v_0 \sin \theta \cos \theta + \left( {\cos \theta } \right)\sqrt {v_0^2 \sin ^2 \theta + 2gh} } \right)[/tex]
*But, which [tex]\theta[/tex] will maximize the range? Here, I simply find the roots of [itex]{dx}/{d\theta}[/itex]:
[tex]\frac{{dx}}{{d\theta }} = \frac{{v_0 }}{g}\left[ {v_0 \cos 2\theta + \frac{{v_0^2 \sin \theta \cos ^2 \theta }}{{\sqrt {v_0^2 \sin ^2 \theta + 2gh} }} - \left( {\sin \theta } \right)\sqrt {v_0^2 \sin ^2 \theta + 2gh} } \right] = 0 \Rightarrow[/tex]
[tex]v_0 \cos 2\theta \; + \; \frac{{v_0^2 \sin \theta \cos ^2 \theta }}{{\sqrt {v_0^2 \sin ^2 \theta + 2gh} }} \; - \; \left( {\sin \theta } \right)\sqrt {v_0^2 \sin ^2 \theta + 2gh} = 0 \Rightarrow[/tex]
To simplify this equation, I can multiply both sides by
[tex]\frac{{\sqrt {v_0^2 \sin ^2 \theta + 2gh} }}{{v_0 \sin \theta }}[/tex]
and continue to get :smile::
[tex]\left( {\cos 2\theta } \right)\sqrt {v_0^2 + 2gh\csc ^2 \theta } \; + \; v_0 \cos 2\theta \; + \; 2v_0^{ - 1} gh = 0 \Rightarrow - \sqrt {v_0^2 + 2gh\csc ^2 \theta } = v_0 \; + \; 2v_0^{ - 1} gh\sec 2\theta \Rightarrow[/tex]
[tex]\csc ^2 \theta = 2\sec 2\theta \left( {1 + v_0^{ - 2} gh\sec 2\theta } \right)[/tex]
Now, we can multiply both sides by [itex]\cos 2\theta[/itex], to get
[tex]\cot ^2 \theta - 1 = 2\left( {1 + v_0^{ - 2} gh\sec 2\theta } \right) \Rightarrow \cot ^2 \theta - 2v_0^{ - 2} gh\sec 2\theta = 3 \Rightarrow ??[/tex]
And now I'm stuck; any ideas?
I haven't worked it all out, but it seems like this should lead directly to the solution: Take the equation while it still says
Now raise both sides to the -1 power:
[tex]\sin^2\theta = \frac{\cos 2\theta} {2(1+ v_0^{ - 2} gh\sec 2\theta) } = \frac{\cos^2 2\theta} {2\cos 2\theta+ 2v_0^{ - 2} gh}[/tex]
Then substitute for [itex]\sin^2 \theta[/itex]:
[tex]\sin^2\theta = 1 - \cos^2 \theta = 1 - \frac{\cos 2\theta +1} {2}[/tex]
Now all of the trig functions are [itex]\cos 2\theta[/itex] so its just a quadratic equation.
Right...therefore,
[tex]1 - \cos 2\theta = \frac{{\cos ^2 2\theta }}{{v_0^{ - 2} gh + \cos 2\theta }} \Rightarrow \left( {1 - \cos 2\theta } \right)\left( {v_0^{ - 2} gh + \cos 2\theta } \right) = \cos ^2 2\theta \Rightarrow[/tex]
[tex]v_0^{ - 2} gh \; + \; \left( {1 - v_0^{ - 2} gh} \right)\cos 2\theta \; - \; 2\cos ^2 2\theta = 0 \Rightarrow 2v_0^2 \cos ^2 2\theta \; - \; \left( {v_0^2 - gh} \right)\cos 2\theta \; - \; gh = 0 \Rightarrow[/tex]
[tex]\cos 2\theta = \frac{{v_0^2 - gh + \sqrt {v_0^4 + 6v_0^2 gh + g^2 h^2 } }}{{4v_0^2 }} \Rightarrow \theta = \frac{1}{2}\cos ^{ - 1} \left[ {\frac{1}{4} - \frac{{gh - \sqrt {\left( {v_0^2 + gh} \right)^2 + 4v_0^2 gh} }}{{4v_0^2 }}} \right][/tex]
*Is this correct??
*Can the expression within the arccosine be further simplified?
[tex]\left( {\cos 2\theta } \right)\sqrt {v_0^2 + 2gh\csc ^2 \theta } \; + \; v_0 \cos 2\theta \; + \; 2v_0^{ - 1} gh = 0 \Rightarrow - \sqrt {v_0^2 + 2gh\csc ^2 \theta } = v_0 \; + \; 2v_0^{ - 1} gh\sec 2\theta[/tex]
You get your last expresssion here by dividing by [tex]cos2\theta[/tex], but when h = 0, [tex]Cos2\theta = 0[/tex].
When projecting upon horizontal ground, the optimum angle is 45º.
In your final expression (last post), what value of [tex]\theta[/tex] do you get for h = 0?
Well, the original problem explicitly stated
bomba923 said:
If [itex]h > 0[/itex], what [itex]\theta[/itex] .. ..
Somewhat similar as to why [itex]a \ne 0[/itex] when solving [itex]a x ^ 2 + b x + c = 0[/itex] for [itex]x[/itex]. You cannot divide by [itex]2 a[/itex] in the quadratic formula if [itex]a = 0[/itex]. However, if [itex]a = 0[/itex], then there are simpler ways of solving quadratics and get solutions for x. But why is this an issue here? What's wrong with it, if I consider only [itex]h > 0[/itex] ?
However, we can substitute [itex]h = 10 ^ {-10}[/itex]...or any number sufficiently close to zero--->we can also substitute h = 0. Also, let [tex]v_0 = 10[/tex]. Needless to say, [itex]g = 9.8[/itex].
Therefore, the optimal angle would be:
[tex]\theta = \frac{1}{2}\cos ^{ - 1} \frac{1}{2} = \frac{\pi }{6}[/tex]
However, the correct answer is [tex]\theta = {\pi/4}[/tex].
*Thus, I think my formula for the optimal [tex]\theta[/tex] for maximum range is incorrect...But why? Where have I gone wrong? Seriously, why is it wrong do divide by [itex]\cos {2\theta}[/itex]...I mean, I did state [itex]h > 0[/itex].
|*It seems there's a problem. But what exactly is it? How can it be solved?
And what is the REAL, the True formula to calculate the [tex]\theta[/tex] ?
*According to a friend's calculator, the optimal [tex]\theta[/tex] for maximum range is given by the formula:
[tex]\theta = \cos ^{ - 1} \left[ {\frac{{\sqrt {2\left( {2gh + v_0^4 } \right)} }}{{2\sqrt {gh + v_0^4 } }}} \right][/tex]
But is this truly the formula to find the optimal [tex]\theta[/tex] for the maximum range? If so, how is it derived?
In the quadratic formula, you can't have a=0, not only because division by zero is out, but because if a = 0, then you don't have a quadratic, just a linear expression in x. The QF is for quadrtic expressions, so having a != 0 is a condition of using it.
In your optimum angle problem, why do you not allow h=0?
h=0 is the state of the problem when projecting upon horizontal ground and any (general) expression should be able to take h=0 as one possible value.
Also, putting h=0 allows you to check the accuracy of your own general solution for one specific case.
I solved this problem in another forum, some time ago, but I can't find my solution. I'll have another look and see if I can figure out something.
From reading your previous post, it seemed that you saw h = 0 as a problem...a problem when dividing by [itex]cos {2\theta}[/itex] when solving [itex]{dx}/{d\theta} = 0[/itex] for for [tex]\theta[/tex]. Would it be this step that invalidates my original formula for the [tex]\theta[/tex] ?
In some other forum (non-PF)...or just in another section of PF?
Can you remember some phrases/quotes, that I may google-search for it?
Aside from that, how fares the calculator solution?
Not sure how this was derived...but it appears to work:
@h=0, [itex]\theta = {\pi}/{4}[/itex], and [itex]{d\theta}/{dh} < 0[/itex] as expected.
This can be a problem, but as a problem can be circumvented by taking out [tex]cos2\theta[/tex] as a factor, which can be equated it to zero as a solution of the expression. This would give you [tex]\theta = \pi/4[/tex] as one solution! So now I don't think that's the problem.
bomba923 said:
... In some other forum (non-PF)...or just in another section of PF?
It's from TSR maths forum, but I've already searched for it with no luck. I'm sorry but I can't remember any significant details - but it was the exact same problem. Fiinding the optimum angle for shooting off a cliff/hill top.
Still working on it. But there's a problem in the expression you gave. gh and [tex]v_0^4[/tex] should have the same units. Shouldn't it be [tex]v_0^2[/tex]
Worked through the problem again, and as answer got,
[tex]cos2\theta = \frac{gh}{gh + v_0^2}[/tex]
which, in effect, is the same the one you got,
(once you chage the [tex]v_0^4[/tex] to [tex]v_0^2[/tex])
Found your error - it was just a wrong sign!
[tex]\left( {\cos 2\theta } \right)\sqrt {v_0^2 + 2gh\csc ^2 \theta } \; + \; v_0 \cos 2\theta \; + \; 2v_0^{ - 1} gh = 0[/tex]
The final term [tex]+ \; 2v_0^{ - 1} gh[/tex] should be [tex]- \; 2v_0^{ - 1} gh[/tex]
If you work through from there on, you should end up with the expression I got, which you can simplify to the one from your friend with the calculator.
  • · Replies 21 ·
  • · Replies 25 ·
  • · Replies 38 ·
