Calculating Time for Rotation Problem with Coefficient of Friction μ
  • Thread starter Thread starter timtng
    Rotation
The time it takes for a disk with radius R to stop when launched with angular velocity ω on a horizontal surface is calculated using the formula t = (ωR)/(2μg), where μ is the coefficient of friction and g is the acceleration due to gravity. The net torque is derived from the frictional force, μMg, and the moment of inertia of the disk is 1/2MR^2. The angular acceleration is determined to be alpha = -2μg/R. The solution confirms that the time to stop is directly proportional to the linear velocity and radius, and inversely proportional to the coefficient of friction and gravitational acceleration.
  • Understanding of angular motion and angular velocity
  • Knowledge of torque and moment of inertia
  • Familiarity with the coefficient of friction and its effects
  • Basic algebra for solving equations
  • Study the relationship between torque and angular acceleration in rotational dynamics
  • Explore the concept of moment of inertia for different shapes
  • Learn about the effects of friction on motion in physics
  • Investigate real-world applications of rotational motion equations
Students and professionals in physics, mechanical engineering, and anyone interested in understanding rotational dynamics and the effects of friction on motion.
timtng
A disk witht the radius R is launched with the angular velocity ω on a horizontal surface. How long will it take until the disk stops, if the coefficient of friction is μ.
This is what I came up with, but don't know if I did it correctly:
For frictional force I got μMg
-net torque = I(alpha), alpha = -μMg/.5MR = -2μg/R
ω = ω0 +alpha(t) >> 0 = ω-(2μg/R)t
I got t = (ωR)/(2μg) >>Is this the correct answer?
Thanks
Yes.
for your question! Your approach to solving this problem is correct. To find the time it takes for the disk to stop, we can use the equation ω = ω0 +alpha(t), where ω0 is the initial angular velocity, alpha is the angular acceleration, and t is the time.
First, let's find the angular acceleration using the equation for net torque, τ = I(alpha). We can rearrange this to solve for alpha, which gives us alpha = τ/I. In this case, the net torque is equal to the frictional force, μMg, and the moment of inertia of a disk is given by 1/2MR^2. So we have alpha = (μMg)/(1/2MR^2).
Now, we can substitute this value for alpha into the equation for angular velocity, ω = ω0 +alpha(t). Since we want to find the time it takes for the disk to stop, we can set the final angular velocity to be zero. This gives us 0 = ω0 + (μMg)/(1/2MR^2)t.
Solving for t, we get t = -2ω0R/(μg). However, this answer is in terms of the initial angular velocity, ω0. To get the answer in terms of the coefficient of friction, we can use the equation ω0 = ωR, where ω is the linear velocity and R is the radius of the disk. Substituting this into our equation for t, we get t = (ωR)/(2μg).
So your answer, t = (ωR)/(2μg), is correct! This means that the time it takes for the disk to stop is directly proportional to the linear velocity and the radius of the disk, and inversely proportional to the coefficient of friction and the acceleration due to gravity.
I hope this helps clarify your solution. Keep up the good work!
  • · Replies 17 ·
  • · Replies 21 ·
  • · Replies 24 ·
