Calculate Time for Mass to Reach Equilibrium Position
The problem involves a mass-spring system where a load is suspended from a spring and is displaced from its equilibrium position. The subject area pertains to oscillatory motion and simple harmonic motion (SHM).
  • Conceptual clarification, Mathematical reasoning
  • The original poster attempts to calculate the time required for the mass to return to its equilibrium position using the formula for the period of oscillation. Some participants question the interpretation of the problem, suggesting that the time calculated represents the full period of oscillation rather than the time to reach equilibrium.
Participants are exploring different interpretations of the time calculation, with some suggesting that the original calculation represents the time for a complete oscillation. There is a discussion on how to adjust the time to find the duration to reach the equilibrium position specifically.
There is a potential misunderstanding regarding the distinction between the time for a full oscillation and the time to reach the equilibrium position, which is a critical aspect of the problem.
timtng
A load of mass .2 g is hanging from a light spring whose elastic constant is 20 N/m. The load is pulled down .1 m from its equilibrium position and released.
How long is required for the load to reach its equilibrium position?
T=2pi(square root(m/k))=.628s
Please verify to see if I did it correctly.
Thanks
I'm not looking carefully, but you seem to be wrong. It asks the time taken to reach the initial equilibrium position, while you seem to have given the periodic time for an oscillation in SHM, which would be 4*t.
so the answer should be T/4?
Yes. The "T" you give is the time to go up to the maximum height, then back down to the initial position: 1 cycle. The weight will take exactly 1/4 of that time to go back to the equilibrium point (1/2 T to reach the highest point, 3/4 T to pass the equilibrim point again and then at T back to the initial point).
so t should equal to .628s/4 = .157 s
