| Thread Closed |
Poisson's Spot |
Share Thread | Thread Tools |
| Aug24-05, 08:20 AM | #1 |
Poisson's Spot
Hi
hoping someone can help me with this problem. If I block plane monochromatic light (wavelength lambda) with a circular disc of radius r, and then look at the diffraction pattern on a screen placed a distance x behind the disc, I get a bright spot in the centre of the shadow. All well and good. What I want to know is how do the intensity and radius of that central spot vary as a function of x. Specifically I want to know how small I need to make x in order to effectively eliminate the bright spot. Clearly at x=0 there is no bright spot - as x increases I don't know whether the spot appears with increasing radius or increasing intensity (presumably both) but I need to be able to put some numbers in to find at what point the spot becomes intolerably bright/large. For anyone interested the reasoning behind my problem is a botched photolith job that I'm trying to do an autopsy on and avoid repeating the same mistakes!! Thanks very much for any help anyone can give, Dan |
| Aug24-05, 08:49 AM | #2 |
Mentor
Look up a mathematical discussion of Fraunhofer diffraction in a physical optics text (or just poke around the web). That spot is also called the Airy disk. The intensity is described by a Bessel function. Here's a site that describes it a little: http://dustbunny.physics.indiana.edu...n/poisson.html
| Aug24-05, 01:18 PM | #3 |
Hey Doc
cheers for the reply. Yeah I've been looking through the textbooks (Fresnel diffraction rather than Fraunhoffer I think) but it's not as simple as I'd hoped. The Bessel functions from the standard analysis will never give you the dot disappearing, as the analysis is invalid for x approaching zero (which it's going to have to do.) The classic undergrad approach fails at the first hurdle. I've got a feeling it's going to involve a lot of unpleasant maths starting right from first principles of diffraction (doubtless quickly resulting in an analytically impossible integral) - just wondered/hoped whether anyone out there had already ploughed through this or had a better way in mind! |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Poisson's Spot
| Poisson's equation in 2 dimensions | Advanced Physics Homework | 8 | ||
| Poisson's Identity | Differential Geometry | 1 | ||
| Poisson's equation | Calculus & Beyond Homework | 4 | ||
| Poisson's ratio | Mechanical Engineering | 11 | ||
| Poisson's ratio | Introductory Physics Homework | 2 | ||
