Calculating Net Force of a Helium Balloon in Thermodynamics - Tips and Tricks
  • Thread starter Thread starter physicsCU
    Thermodynamics
The discussion focuses on calculating the net force of a helium balloon in thermodynamics, specifically addressing the correct approach to include both the mass of the balloon and the helium. The balloon has a diameter of 10 meters, with an air density of 1.16 kg/m³ and helium density calculated as 1/7 of air density. The buoyant force is determined using the formula: buoyant force = density(air) * g * Volume(balloon). The correct net force calculation yields an acceleration of 16.5 m/s² when all mass components are considered, including the helium's mass.
  • Understanding of buoyant force calculations in fluid dynamics
  • Knowledge of density and its role in thermodynamic equations
  • Familiarity with Newton's second law of motion (F = ma)
  • Basic principles of volume calculation for spherical objects
  • Learn how to calculate buoyant force using Archimedes' principle
  • Explore the relationship between density, mass, and volume in thermodynamics
  • Study the effects of different gases on buoyancy and net force
  • Investigate advanced applications of Newton's laws in fluid mechanics
This discussion is beneficial for physics students, educators, and anyone involved in thermodynamics or fluid mechanics, particularly those interested in buoyancy and force calculations involving gases.
physicsCU
OK, I have been working on this for a while.
I have a balloon, filled with helium.
mass = 140 kg
density(air) = 1.16 kg/m^3
density(He) = 1/7*density(air)
diameter of balloon = 10 m
buoyant force = density(air)*g*Volume(balloon)
weight = m*g
net force = buoyant force - weight = ma
I need to solve for a. The book tells the answer (16.5 m/s^2), so I know what I need to get to, but doing the steps above, I haven't gotten close.
Anybody have any ideas to help out?
Thanks!
You need the mass of the 'entire' balloon, that is, the mass of the container itself which is 140 kg, plus the mass of the helium inside. I think that's about the only point where it can really go wrong.
Why don't you post what you got for the volume and mass of the balloon and what you got for the bouyancy.
ok, volume was 523.6 m^3, mass ended up being 226.768 kg.
i had forgot the mass of the helium, i got the right answer now, thanks!
9K
  • · Replies 62 ·
  • · Replies 84 ·
9K
