Why Does a Pulley System Show Different Tensions for Different Masses?
  • Thread starter Thread starter Psi
    Tension
The discussion clarifies the concept of tension in a pulley system with unequal masses. It establishes that tension is not uniform in the rope when different weights are involved, as the heavier block exerts a greater downward force. The tension in the section of the rope holding the heavier block is greater than that in the section holding the lighter block due to the differing gravitational forces acting on each mass. This understanding is crucial for solving related physics problems accurately.
  • Understanding of Newton's laws of motion
  • Basic knowledge of gravitational force
  • Familiarity with the concept of equilibrium in physics
  • Experience with pulley systems and tension forces
  • Study the principles of Newton's second law of motion
  • Explore the concept of torque and its effects on pulley systems
  • Learn about the dynamics of systems with multiple masses
  • Investigate real-world applications of pulley systems in engineering
Students studying physics, educators teaching mechanics, and anyone interested in understanding the dynamics of pulley systems and tension forces.
Psi
I am working out a homework problem in which two unequal masses are on either end of a rope, which is wrapped around a pulley. The problem asks what the tension is in the part of the rope holding "(a) the lighter block, and (b) the heavier block". The solution manual reports different answers for these parts, but I thought tension was always the same in the same rope...?
Am I right? If not, could you explain what is happening in this problem?
Thanks a lot!
--Psi
Tension would be the same if the rope were massless and the pulley were massless and frictionless. Consider that the rope exerts torque on the pulley.
Hello Psi,
Thank you for reaching out about this tension problem. It is understandable that you are confused about the different answers reported in the solution manual. While it is true that tension is always the same in the same rope, it is important to consider the different forces acting on the rope in this particular scenario.
In this problem, the two unequal masses are exerting different forces on the rope due to gravity. The heavier block exerts a greater downward force on the rope, while the lighter block exerts a smaller downward force. This means that the tension in the rope will be different in each section, as the tension is equal to the force applied on the rope.
To better understand this, let's think about the forces acting on the rope. On one side, we have the tension force pulling the rope upwards, and on the other side, we have the weight of the heavier block pulling the rope downwards. In order for the rope to remain in equilibrium, the tension force must be equal to the weight of the block. This means that the tension in the section of the rope holding the heavier block will be greater than the tension in the section holding the lighter block.
I hope this explanation helps clarify the concept of tension in this problem. It is important to always consider the different forces acting on an object when determining the tension in a rope. Please let me know if you have any further questions or concerns.
  • · Replies 18 ·
  • · Replies 22 ·
  • · Replies 38 ·
  • · Replies 27 ·
  • · Replies 18 ·
  • · Replies 22 ·
