Understanding Triboelectrics: Explaining the Transfer of Charge through Friction
  • Thread starter Thread starter TheoehT
This discussion focuses on the principles of triboelectric charging, specifically the transfer of charge through friction between a perspex rod and silk, resulting in a charge of 0.02 µC. The calculation of the number of electrons transferred is established as 1.25 x 10-11 electrons, derived from the formula involving the charge of an electron (1.6 x 10-19 C) and the conversion of microcoulombs to coulombs. Additionally, when this charge is transferred to an electroscope with an initial charge of +0.01 µC, the total charge becomes +0.03 µC, leading to increased deflection of the electroscope's leaves due to the repulsion of like charges.
  • Understanding of microcoulombs (µC) and their conversion to coulombs (C)
  • Knowledge of the charge of an electron (1.6 x 10-19 C)
  • Familiarity with the concept of charge transfer through friction
  • Basic principles of electrostatics, including charge interactions
  • Study the principles of triboelectric series and its applications in materials science
  • Learn about the calculations involved in electrostatic charge transfer
  • Explore the behavior of electroscopes and their use in measuring charge
  • Investigate the effects of charge accumulation and discharge in various materials
Students in physics, educators teaching electrostatics, and anyone interested in the practical applications of triboelectric charging and electrostatic principles.
TheoehT
Triboelectrics... Help please.
this problem is a worked example in my textbook.. but it looks like they have just pulled numbers from thin air. I really don't understand how they got these answers.. can anyone explain?
A perspex rod is rubbed with a piece of silk. it acquires a charge of 0.02uC
a) How many electrons are transferred?
b) is this charge is now transderred to an electroscope with charge +0.01uC what will be the net state of the electroscope?
Book's Solution:
0.02 x 10^-6 x 6.25 x 10^18 electrons -or-
a) 1.25x10^-11 electrons transferred.
b) total charge on the electroscope after transfer:
0.02uC + 0.01uC = 0.03uC (+)
the electroscope leaf deflection will increase and the net charge on the electroscope is now +0.03uC = 1.87x10^11 electrons depleted
I really don't understand, can anyone help?
okay here you go.
1 uC ( micro-columb ) = 1 * 10^-6 C
Charge on 1 electron = 1.6 x 10^-19 C
Number of electrons in 1 Columb = 1/(1.6 * 10^-19)
Which = 6.25 * 10^18 -points solution-
Amount of charge transferred = 0.02 * 10^-6 (points micro columb value above)
Amount of electrons transferred = Amount of charge transferred * number of electrons/C
so...
0.02 * 10^-6 * 6.25 * 10^18 = 1.25 * 10^-11 (electrons transfered)
For b, when u rub the rod with a piece of silk, it acquires a negative charge yeah?(electrons go from the rod to the silk)
So, if u transfer this charge to the electroscope, which already has +0.01uC, its total charge becomes +0.03uC
+0.02uC +0.01uC = +0.03uC
The deflection increases because like-charges repel, so if i have a higher charge on the scope, the leaves both possesses a higher charge, and thus experience more repulsion.
1.87 * 10^11 ?
i think u meant 1.87 * 10^-11
that'll be the number of electrons the electroscope is missing, if u calculate, that equals to 0.03uC
Thank ruby for this.. her fault
thank catherine for this, her fault
  • · Replies 16 ·
14K
