Finding Probability of Lifetime for Light Bulbs Using Normal Distribution Table
The discussion revolves around finding the probability of a light bulb's lifetime using a normal distribution table. The light bulb's lifetime is normally distributed with a mean of 650 hours and a standard deviation of 40 hours. The specific question is about determining the probability that a randomly selected light bulb has a lifetime between 700 and 850 hours.
  • Participants discuss the conversion of the lifetime values into Z-scores using the formula Z = (X - μ) / σ. There is an exploration of how to apply this to the given range and the implications of the Z-score exceeding typical table limits.
Some participants have provided guidance on using the normal distribution table and converting values to Z-scores. However, there is a lack of consensus on how to handle Z-scores that exceed the table's range, and one participant expresses difficulty in obtaining a solution.
There is mention of the normal distribution table not covering Z-scores beyond 4, which raises questions about the likelihood of extreme values and how to interpret them in the context of this problem.
~angel~
Note: You'll need the Normal Distribution Table.
A certain type of light bulb has a lifetime in hours which is normally distributed with mean μ=650 and standard deviation σ=40. What is the probablility that a randomly selected light bulb has a lifetime in the range (700, 850)?
Now this is how I tried to do this:
We have to find P(700 ≤ X ≤ 850), but we need it in terms of Z.
Now,
Z= (X-μ)/σ
Z= (X-650)/40
But we have to apply this to all the sides of the inequality, so we end up with
P(1.25 ≤ (X-650)/40 ≤ 5)
= P(1.25 ≤ Z ≤ 5)
But using the Normal Distribution Table, there is no probability for the "5" bit of the inequality. So I'm not sure how to do this.
Thanks.
Let me explain on how to use the Normal distribution Table. The normal distribution table is... well... normal! It means it has been normalized with a mean of 0 and a standard deviation of 1. To use this standardized table with bell-shaped distributions you get in real life, you need to get the corresponding value of Z. You are in fact stretching/compressing your real life distribution curve accordingly so that it looks like the normal distribution that you do have on the table!
To convert, you have the equation you mentioned
Z= (X-μ)/σ
The subtraction of the mean does the horizontal shift fix, and the dividing by the standard deviation takes care of the fatness/thinness so that they correspond to each other now.
You are looking for a X1=700, and X2=850 right? What does this correspond to on the Z-table? pluggin them in, you will get Z1, and Z2, now you are looking for
P(Z1 ≤ Z ≤ Z2)
which is possible to do ^_^
A really small table might not go all the way out to z=5.
What do you get from the table at z=3.5?
What do you get from the table at its highest (z= 3.99)?
There's such a small likelihood of finding a bulb with Z>5
that tables ignore the probability of such a miracle bulb.
Thanks for your help, but I can't get the answer. The table goes up to 4 only. I tried your way lightgrav, but it's not right. Is there any other way to work this out?
