Submarine fluid physics problem
The maximum depth a submarine can reach without damaging its circular window, which has a diameter of 30 cm and can withstand a force of 5.2x10^5 N, is calculated to be 751 meters. The pressure at depth is derived from the equation P = ρgh, where ρ is the density of water (1000 kg/m³), g is the acceleration due to gravity (9.8 m/s²), and h is the depth. The area of the window is calculated as A = π(0.15 m)², which equals approximately 0.0708 m². By equating the force to pressure times area, the depth is determined using the formula h = F / (Aρg).
  • Understanding of fluid mechanics principles, specifically pressure calculations.
  • Familiarity with the equation P = ρgh for calculating pressure at depth.
  • Ability to calculate area of a circle using A = πr².
  • Basic knowledge of unit conversions, particularly between centimeters and meters.
  • Study the derivation and applications of the hydrostatic pressure equation P = ρgh.
  • Learn about the effects of pressure on materials, particularly in underwater environments.
  • Explore the design considerations for submarine windows and pressure vessels.
  • Investigate real-world applications of fluid mechanics in engineering and marine technology.
Students and professionals in engineering, particularly those focused on marine engineering, fluid mechanics, and materials science. This discussion is also beneficial for anyone involved in submarine design or underwater exploration.
cathliccat
Ok, 'A circular window with a 30 cm diameter in a submarine can withstand a maximum force of 5.2x10^5N. What is the maximum depth (in m) in a lake to which the submarine can go without damaging the window round off to the nearest whole number?'
I tried P=F/A=pAhg/A, so I converted 30 cm to meters, solved for P then tried to find h. p=1000, A=pi*.15^2, h=?, g =9.8. So .070 = 9.8h, h=7.21X10^-6. That can't be right because then the submarine wouldn't move at all before the window busted.
Can someone tell me where I went wrong? Thanks!
This is correct. It seems that somehow you later derived the equation A = g h, since you said "0.70 = 9.8 h." I'm not sure at all where got this! You have the right equation -- just solve it for h.
The pressure at a depth of h meters in a fluid is given by
P = [rho] g h
The force on the window is indeed equal to
F = P A or P = F / A
where A is the area of the window.
Equating these, we get
P = F / A
[rho] g h = F / A
h = F / (A [rho] g)
Does this make sense?
- Warren
I'm trying to figure out where you got the "0.70" in ".070 = 9.8h"!
You are correct that P=F/A=ρAhg/A or, since it is F we are given rather than P, F= ρAhg.
You are given that F= 5.2x10^5N so that hg=9.8h= 5.2x10^5/(ρA)
The Area is π(.15)2= 0.0708 sq.m so F/A= 7356495. Taking &rho= 1000 gives F/(ρA)= 7356.495= 9.8h so h= 751 meters.
17K
10K
