Could someone check me on this?
  • Thread starter Thread starter physicsCU
The discussion revolves around a problem involving forces in equilibrium, specifically focusing on determining the magnitudes of three unknown forces based on their directional components and the known force.
  • The original poster attempts to find the magnitudes of forces F2, F3, and F4 using equilibrium equations in three dimensions. Some participants suggest using computational tools to verify calculations, while others clarify the relationship between force components and their magnitudes.
The discussion is ongoing, with participants exploring different methods of verification and addressing potential errors in calculations. There is acknowledgment of the complexity involved in manual calculations, and some guidance on using software tools has been provided.
Participants note that the original poster has complete information about F1 but only directional information for F2, F3, and F4. There are indications of sign errors in previous calculations that have been addressed by one participant.
physicsCU
OK, I have four forces in equilibrium
F1 = 50i N
e2 = -0.485i + 0.485j - 0.728k
e3 = -0.557i + 0.743j + 0.371k
e4 = -0.371i - 0.743j + 0.557k
I need to find the magnitudes of F2,F3,and F4
I got F2 = 373.67 N (this might be a + or -, not sure, thinking +)
F3 = 346.43 N
F4 = 102.44 N
I used the equilibrium in each direction (x,y,z) and then I had three equations with three unknowns.
If someone could confirm that or tell me where I messed up, that would be great. Thanks!
It's very tedious work to do manually. Hopefully for you, someone will check it using a math program. I suggest you get one of those and learn how to use it. Very usefull to check answers like this one.
I have Mathematica, but I don't know how I would check it on there. Any thoughts?
If the body is in equilibrium under the action of no. of forces, then sum of their components in x,y and z direction separately is zero.
If the force is given in the form
F = Fx i + Fy j +Fz k then it means the Fx , Fy, Fz are components in the corresponding direction and the magnitude is given by sqrt(Fx^2 + Fy^2 + Fz^2)
need not to solve the equations if the values are given.
He doesn't know the magnitude of F_2, F_3 and F_4. He known everything about F_1 and only the direction for the other 3. The directions are given by the unit vectors e_i.
I solved the problem, I had a bunch of sign errors, but I fixed them.
I used MATLAB to check it, but that was wrong. No worries, I am just saying.
