Which Object Reaches the Bottom of an Incline Fastest?
The discussion centers on the dynamics of four objects—a hoop, a solid cylinder, a solid sphere, and a box—rolling and sliding down an incline of height H. All objects have the same mass M and radius R. The key conclusion is that the box reaches the bottom with the greatest speed due to having no rotational kinetic energy, while the hoop arrives with the smallest speed due to its higher moment of inertia (I = MR²). The principle of conservation of energy is crucial in understanding the relationship between potential energy and kinetic energy for these objects.
  • Understanding of conservation of energy principles
  • Familiarity with moments of inertia for different shapes
  • Knowledge of translational and rotational kinetic energy equations
  • Basic kinematics, particularly the relationship between linear and angular velocity
  • Study the conservation of energy in mechanical systems
  • Learn about moments of inertia for various geometric shapes
  • Explore the relationship between translational and rotational motion
  • Investigate the effects of friction on rolling motion
Students of physics, particularly those studying mechanics, educators explaining concepts of energy and motion, and anyone interested in understanding the dynamics of rolling and sliding objects.
mpm
I have a mechanics question that I can't seem to figure out. I've spent quite a bit of time on it but don't have much of an answer.
If anyone can help I would appreciate it.
Round objects are rolling without slipping down an inclined plane of height H above the horizontal. The box is sliding without friction down the slope. All round objects have the same radius R & the same M, which is also the mass of the box. The moments of intertia for the round objects are: Hoop: I = MR^2, Cylinder = I (1/2)MR^2, Sphere I = (2MR^2)/5. The 4 objects are released, one at a time, from the hiehg H. Which one arives at the bottom with the greatest speed? Why? Which arrives with the smallest speed? Why? What physical principle did you use to answer these questions?
The professor wants answers in words and not so much equations.
I would think the box would be the slowest. If I remember right, an object rotates faster if the mass is in the center instead of on the outside edges.
But I am really confused.
Thanks,
Mike
Have you covered conservation of energy yet?
Assuming you have, you know that all of the objects start with the same potential energy (MgH). All of this potential energy is converted into kinetic energy by the time it reaches the bottom (no frictional losses). This kinetic energy can be thought of as the sum of translational kinetic energy (mv2/2) and rotational kinetic energy (Iω2/2). From kinematics, you know that the rotational speed is related to the translational speed (ω=v/R) for no slip.
You are asked about the relative speeds of the objects, so you are interested in v, the tranlsational speed. If you look at the conservation of energy, you will find out how the magnitude of the object's moment of inertia affects the relative contribution of rotational to translational kinetic energy and, therefore, the final value of the speed (you don't have to actually solve it, you just need to see the relationship). I hope that helps.
Hint: the block is not the slowest; it does not rotate (has no rotational kinetic energy).
  • · Replies 28 ·
  • · Replies 40 ·
  • · Replies 27 ·
