Is V Also a Vector Space Over the Real Numbers?
The discussion centers on whether the set V, defined as V = {(a1, a2, ..., an): ai in C for i = 1, 2, ... n}, is a vector space over the field of real numbers. The conclusion is that V is indeed a vector space over the reals, as the operations of coordinatewise addition and scalar multiplication with real numbers satisfy the vector space properties. The key point is that while the elements of V are complex numbers, the scalars used in multiplication can be real numbers, which does not restrict the resultant vectors from remaining in V.
  • Understanding of vector space definitions and properties
  • Familiarity with complex numbers and their operations
  • Knowledge of scalar multiplication and addition in vector spaces
  • Basic understanding of fields in mathematics
  • Study the properties of vector spaces over different fields
  • Learn about the relationship between complex numbers and real numbers in vector spaces
  • Explore examples of vector spaces defined over various fields
  • Investigate the implications of scalar multiplication in vector spaces
Mathematicians, students of linear algebra, and anyone interested in the properties of vector spaces and their applications in complex analysis.
loli12
Let V = {(a1, a2, ..., an): ai in C for i = 1, 2, ... n}; (C=complex numbers) ; so, V is a vector space over C. Is V a vector space over the field of real numbers with the operaions of coordinatewise addition and multiplication?
I thought the answer to this question is No since after we perform the operations on any two of the elements in C, we are getting some other complex numbers which is not an element in R. But the book says Yes to the question. Can anyone please tell me what's wrong with my concept and what is the correct way to brainstorm this question?
Thanks!
does anyone has any idea to the problem? or is there any other missing information that I have to provide? Please Please help!
Look at the DEFINITION of "vector space over field F".
A vector space over a field is:
A set of objects with addition and scalar multiplication defined such that
1) For all x, y in the set, x+ y is also in the set and all the "group" properties hold.
Okay, if our set is the set of complex numbers the sum is a complex number and it is easy to show that the set of complex numbers, with usual addition, is a group.
In fact, as far as the properties of addition are concerned, the field is irrelevant!
2) For all x in the set, a in the field, ax is in the set, a(x+y)= ax+ay, (a+b)x=ax+ bx (the "distributive laws).
Sure: if x is a complex number, a is a real number, ax is a complex number. The distributive laws hold for all complex numbers and the real numbers are a subset of complex numbers so it doesn't matter if we restrict a to be real!
"I thought the answer to this question is No since after we perform the operations on any two of the elements in C, we are getting some other complex numbers which is not an element in R."
The vectors are in C, not R. It's only the "scalars" we multiply by that have to be in R. Making R the field means we restrict what we can multiply by, not the possible result.
  • · Replies 0 ·
9K
  • · Replies 48 ·
10K
  • · Replies 25 ·
