Securing PVC Pipe Cap: A Challenge
The discussion centers around the challenges of securing a PVC pipe cap in a semi-pressurized setup, specifically addressing methods to prevent the cap from dislodging under low pressure conditions. Participants explore various solutions and share experiences related to PVC fittings and pressure management.
  • One participant describes the issue of a loose PVC cap that dislodges at low pressures, suggesting the use of petroleum jelly for sealing, which complicates removal.
  • Another participant questions the need for a removable cap, suggesting that PVC is typically glued, which may not align with the original poster's requirements.
  • A participant confirms the need for a removable cap and discusses difficulties in finding suitable threaded fittings that fit their 4" PVC pipe.
  • Several participants share experiences with using threaded caps in similar projects, noting that they are commonly available at hardware stores.
  • One participant suggests checking alternative suppliers like McMaster Carr for hard-to-find parts.
  • Another participant recounts their experience with a potato cannon, discussing the pressures achieved and the sealing methods used, while also sharing safety concerns regarding the use of PVC under pressure.
  • There is mention of the pressure tolerance of a 2-liter soda bottle, with one participant sharing a personal experiment that tested its strength under pressure.
  • Concerns are raised about the potential for catastrophic failure of pressurized containers if impacted.
Participants express a mix of agreement on the challenges of securing the cap and the need for removable fittings, but there is no consensus on the best solution or the specifics of pressure management in PVC applications.
Participants mention limitations in finding compatible fittings and the potential risks associated with using PVC under pressure, but do not resolve these issues or provide definitive solutions.
mrjeffy321
I am building this project which involved to PVC pipe chambers to be semi-pressurized (I know PVC isn’t intended for pressure, but I am not talking 200 psi, 40 to 60 psi theoretical MAX, usually around 5 to 10 psi).
I have a pretty good depiction of the set up made in ASCII art, but I previewed it and it didn’t show up very well since all the extra spaces were removed.
The problem is that the PVC pipe cap is too loose of a fit at even low pressures to stay on, it will fly off into the air. To make matters worse, to ensure there is a seal between the PVC Pipe and the cap, I smear a bunch of petroleum jelly around the cap, so it becomes even easier to slide the cap off.
So I need a way to hold the cap on tight, or strap it down somehow to it won't go shooting of into the air.
My Solution: I taped it. I got some heavy duty tape and strapped it down. It has worked so far in normal operation (< 5 psi, probably, I didn’t measure), but is not a very good long term solution, and it is a hassle to remove when I actually want to remove the cap. Also the tape wears out after a while.
What makes securing the cap so hard is that I can’t drill any holes through the side of the PVC pipe since that will cause a leak for the pressure to vent from.
Another idea I had was to get some type of rope and strap it down by going over the top of the cap and tying it down somehow below.
Or perhaps something like a latch that is attached to the pipe and will grab on something on the cap. Have you seen those coolers that the handle is pointing up, it locks the lid down in place and when you turn the handle to the side it releases the lid, like that. But that would be hard to build.
So, as is my style, when I can’t think of a solution after blankly starting at the pipe for a while, I will pass it on to your guys, the finest engineers on the internet, for help.
If you need me too, I can go into more detail on what the apparatus looks like, or try to draw some pictures for you.
Does this cap need to be removed? PVC used in plumbing is usually glued together with PVC cement.
Depending on the size of the pipe, you can get a slip to thread coupler for pipe from 1-6 inches and screw a plug into the threaded end.
More info will get you a better answer.
Yes, the top cap needs to be removable.
The cap on the other end, which is technically a "Flange" I glued in with PVC cement and that works really well, but I will need to take off the cap semi-often.
The screw plug you speak of is ideal I think, that is what I originally planned on using, but Home Depot didnt have any, or rather thay had it but it didnt fit. I am using 4" PVC pipe and the 4" threaded coupling and screw cap was too big for the pipe, I don't understand.
I attached a text file with the ascii art image to give you a better idea of what it looks like.
My potato cannon (the first one I built) used 4 inch threaded caps. All pvc components were purchased at Home Depot. The 4 inch male and female PVC threaded caps are very common plumbing items, I am sure all HD's stock them.
If you have a hard time finding pipe plugs that large at your local hardware store, you might try McMaster Carr or some other internet provider.
You would think so, but like I said, they had the correct parts but when you go to fit it on the pipe, it didnt work.
I am going to check out another store today and see if they have the parts I need.
Hopefully I didnt put my gas outlet too far up the tube so that when the threaded cap adapter is put on it doenst fit.
I have returned.
Lowes, a had the parts I needed that fit correctly, so it looks like I am set for now.
By the way, GENIERE, about hoe much pressure do you thinnk your potato cannon got up to? Did you do anything special to the screw on lid to make it air tight?
mrjeffy321 said:
… By the way, GENIERE, about hoe much pressure do you thinnk your potato cannon got up to? Did you do anything special to the screw on lid to make it air tight?
Somewhere I read that a 2-liter Coke bottle can withstand 80psi.
Just a wild guess – 150-200psi. It shoots 2 to 3inch by 1 and 1/12inch potato cylinders about 200 yards and maybe 200 feet straight up; I made no attempt ever to measure the distances. The ignition chamber is a 4inch PVC “Tee” with threaded caps on two ends. The vertical part of the “Tee” is necked down to a 1 and 1/12 inch 4 foot PVC barrel. I mounted a bar-b-q ignition in one cap and used the other for clean out. I made no attempt to seal them, they are just hand tightened with minimal effort. I tried several fuels, ending up with automobile starter fluid that I think is ether based but the label did not list the contents. I tried propane and would caution you not to unless you want to shoot mashed potatoes. It was a violent explosion and I think the cannon would not have survived long with dangerous consequences (shrapnel). The pvc glue eventually failed because I think the fuel dissolved it; I just re-glued. I fire it while my grandkids are around and use my body as a shield, making sure they are always behind me. I inspect it after each shot.
80 psi...so that would be 551.6 kPa (I think in kPa, despite what you might think from my other posts).
I know from personal experience that a 2 liter soda bottle can take quite a bit. Using a highly scientific approch a testing its strength under pressure, I once pressurized one using a hand-bicycle pump and then shot a BB gun at the bottle. The bottle survived unharmed.
I do have a pressure gauge on my pipe, so I will be able to find the pressure that I get up to, so I'll be sure to make a note of it.
The one thing you have to watch with a 2 litre under pressure like that is that any impact to the bottle while charged will be enough for it to catastrophically fail.
10K
  • · Replies 39 ·
  • · Replies 17 ·
9K
