Solving Vector Proof: Perpendicular Distance Between Two Parallel Planes
  • Context: Undergrad
  • Thread starter Thread starter Giuseppe
    Proof Vector
The discussion revolves around solving a vector proof related to the perpendicular distance between two parallel planes in three-dimensional space. Participants are exploring the mathematical derivation of the distance formula and clarifying algebraic manipulations involved in the proof.
  • Homework-related
  • One participant presents the formula for the perpendicular distance from a point to a plane and attempts to apply it to find the distance between two parallel planes.
  • Another participant explains that the distance from one plane to another is equivalent to the distance from one plane to a point on the other plane, providing a step-by-step derivation.
  • Several participants express confusion regarding the algebraic manipulation that leads to the transformation of the expression |-d1 + d2| into |d1 - d2|.
  • A later reply clarifies that the transformation is valid due to the property of absolute values, stating that |-A| = |A|.
Participants generally agree on the approach to derive the distance formula, but there is confusion and disagreement regarding the specific algebraic steps involved in the manipulation of the expressions.
The discussion includes unresolved questions about the algebraic steps and assumptions made during the derivation, particularly concerning the properties of absolute values.
Giuseppe
hey guys, i am stuck on one more problem. Can anyone guide me onto the right path on how to start this?
Use this formula for the perpendicular distance between a point and a plane
D= |ax+by+cz-d| all over the square root of (a^2+b^2+c^2)
to show that the perpendicular distance D between the two parallel planes ax+by+cz+d1=0 and ax+by+cz+d2=0 is
D= |d1-d2| all over the square root of (a^2+b^2+c^2)
For a plane {(x, y, z) : ax + by + cz + d = 0} and a point (x', y', z'), you have that the distance from the point to the plane is:
[tex]D = \frac{|ax' + by' + cz' + d|}{\sqrt{a^2 + b^2 + c^2}}[/tex]
The distance from one plane to another parallel plane is obviously the same as the distance from that plane to any single point on the other plane. Suppose (x1, y1, z1) is on plane 1. That means that this point satisfies the equation:
ax1 + by1 + cz1 + d1 = 0
If we isolate d1, we get:
d1 = -(ax1 + by1 + cz1)
-d1 = ax1 + by1 + cz1
Now the distance between plane 2 and plane 1 is the same as the distance between plane 2 and (x1, y1, z1) since (x1, y1, z1) is on plane 1. Using the given formula:
[tex]D = \frac{|ax_1 + by_1 + cz_1 + d_2|}{\sqrt{a^2 + b^2 + c^2}}[/tex]
[tex]D = \frac{|-d_1 + d_2|}{\sqrt{a^2 + b^2 + c^2}}[/tex]
[tex]D = \frac{|d_1 - d_2|}{\sqrt{a^2 + b^2 + c^2}}[/tex]
i get that, but i don't get your last algebraic step. how did the -d1+d2 turn into d1-d2
The question should really be
"how did |-d1+d2| turn into |d1-d2|?"
The answer is, of course, "because |-A|=|A|".
  • · Replies 17 ·
