How Do You Implement a Recursive Function to Calculate Powers in C++?
  • Thread starter Thread starter heavyc
    Science
The discussion revolves around implementing a recursive function in C++ to compute the power of a number, specifically the function "compute_exponent" which calculates a to the power of n, where a is a real number and n is a non-negative integer. The original poster expresses uncertainty about how to begin the problem due to limited class coverage on the topic.
  • Exploratory, Conceptual clarification, Problem interpretation
  • Participants discuss the concept of recursion and its application to the power problem, comparing it to the more common factorial problem. Questions are raised about how to implement recursion for this specific task and whether the factorial method could be adapted for it. There is also a focus on understanding the structure of the function and the necessary input validation.
Some participants have offered insights into the nature of recursion and provided examples related to factorials. There is an ongoing exploration of how to structure the compute_exponent function, with various interpretations and suggestions being discussed. The original poster is encouraged to visualize the problem and consider input handling.
The original poster notes their inexperience with the class material and expresses a desire for guidance on starting the problem. There are mentions of potential constraints regarding input validation for the variables a and n.
heavyc
comp science homework help!
I have this problem in Data Abstraction and problem solving with C++. Here is the problem. Implement a C++ program that calls a recursive function "compute_exponent". compute_exponent function computes a to the power n, where a is a real number and n is a non-negative integer.
I am new to this class and I have no idea what I am doing but i think I know how to put the function together bbut I have no idea how to get this problem started because we didnt really go over to much in this class but if anyone can help me out a little it would be a very grateful thing lol. So please anyone.
do you know what recursion is?
is it told how to immplement recursion on the power(exponrent refers to n not to a^n) problem?
if not do you have an inkling of how you would implement recursion on the power problem.
if you have done the factorial problem look how you could relate it to the power problem.
lastly do you know C++
I find it funny that you are asked to find recursion method for power rather than factorial. But that's probably because factorial was used at the example.
could i use the factorial method to do this one and is it a easier way to go??like i said I am really new to this and yes i do know how to program in C++.
No, that's not what he meant. He just meant that finding n! is much more the "standard" recursion exercise.
"Recursion" means that you can call the function itself inside the function.
For the "factorial" problem, you would do this: 0!= 1 by definition. n!= n(n-1)! so we write a function to do exactly that:
int factorial(int n)
if n= 0 then return 1; //which returns the value 1 and ends the function
else return n*factorial(n-1); //which uses this function again!
wasn't that easy? Just for fun "walk through" that when n= 3.
For an, if n=0, a0= 1 and if n> 0 an= a*an-1. Do basically the same thing as above.
float compute_exponent(float a, int n)
if n= 0 return 1;
else //I'll let you fill it in here
if n= 0 return 1;
so would i do this ??
else return n * compute_exponent(n - 1); // which would return and use the function again?.
Yeah, I think that should work.
The hardest part is starting out. Whether its this or any kind of program, write out as much as you know on paper, put it into groups, try to visualize it in a way that gives you a pattern to work with.
CPP is advanced, the form of coding is not easy to read but its simple once you get it down.
What do you know for sure?
1. The name is compute_exponent
2. The variables are A and N, in the form [txt]a^n[\txt] so var 'a' is the base, and var 'n' is the exponent. How will you get these values from the user when the program runs?
you will print a message to explain the function and ask the user for input. Or the function can be called internally.
At least you will have your function_name and 2 variables to input, then it will return what type?
3. The return type is INT (or FLOAT)
4. The variable 'a' is type REAL; So you test it first for some range
5. The variable 'n' is positive INT; So you test this for being positive and INT
Is that it? Now you can start to picture it, a function, named (name) and the variables, called a, n, types real, int; return type is int
So far you would have
INT compute_exponent (REAL a, INT n) {
// first thing is to check the input, assume the worst
IF ( 0 == a ) {
console.message(error, variable a is zero);
return 0;
IF ( 0 == n ) {
console.message(error, variable n is zero);
return 0;
//you would want to then try the switch statement to validate the input further, but don't waste time if its zero
//now declare any needed local variables
// create your method to multiply 'a' times itself 'n' times
for loop/while loop
your n count is not zero
subtotal *= a
decrement n
return subtotal;
  • · Replies 17 ·
