Threshold Frequency: PE effect
  • Context: Undergrad
  • Thread starter Thread starter Spastik_Relativity
    Frequency Threshold
The discussion revolves around the threshold frequency in the photoelectric effect, exploring its dependencies and implications. Participants consider whether it is influenced by the binding forces between electrons and nuclei or by properties of the photons involved. The conversation touches on theoretical aspects and conceptual clarifications related to the photoelectric effect, particularly in solids.
  • Some participants propose that the threshold frequency is dependent on the properties of the valence band in solids, rather than on individual atomic properties.
  • Others argue that the threshold frequency is influenced by the arrangement of atoms in the crystal structure and the type of solid (metal, semiconductor, etc.).
  • A participant expresses confusion regarding the relationship between threshold frequency and photon momentum transfer to electrons, suggesting a potential connection between threshold frequency and photon wavelength.
  • Another participant emphasizes that the photoelectric effect occurs only in solids due to the lattice structure's role in momentum transfer, challenging the notion of momentum transfer in free electron gases.
  • There is a mention of applying conservation of momentum and Einstein's photoelectric equation to derive a relationship between threshold frequency and photon wavelength, although the clarity of this derivation is questioned.
Participants do not reach a consensus on the exact dependencies of the threshold frequency, with multiple competing views presented regarding the influence of atomic properties, solid-state characteristics, and photon interactions.
The discussion reflects limitations in understanding the nuances of momentum transfer in the photoelectric effect and the specific conditions under which it applies, particularly in relation to solid materials versus free electron scenarios.
Spastik_Relativity
In the Photoelectric effect what is the threshold frequency dependent on?
This isn't homework I was just pondering.
Is it the binding forces between the electron and the nuclues or is it dependent of a property of the photon?
If it's not homework, then it should be in the homework section- I'm moving it to "General Physics".
It depends on the atom (how many and what type of valence electron it has), the crystal structure of the material (how they are arranged when they formed the solid), and what type of solid it became (metal, semiconductor, etc).
I've repeated this many times, but in the typical photoelectric effect, you are dealing with the valence BAND from a SOLID, not individualized atom. The individual atom has lost its identity when it forms a solid since it now has to live with others of its kind. So the atomic property is gone when we deal with the typical photoelectric effect (we're not talking about X-ray photoemission here). This means you have to deal with the property of the SOLID as a whole instead.
Zz.
So the thresold frequency is dependent on the properties of the valency band, right?
Because i was fiddling around with waves and the idea that in the Photoelectric effect that either none or all of the momentum of the photon is transferred to the electron and i came up with a relationship between threshold frequency and the wavelength of the photon.
It was confusing.
It was confusing.
Eh?
Your post is confusing too! It is why photoelectric effect can only occurs in solids - the lattice takes up the photon's in-plane momentum and the electron's recoil momentum! You do not get a photoelectric effect on free electron gas. Refer to any text or review on photoemission spectroscopy.
Zz.
ZapperZ said:
Eh?
Zz.
Yeah I get that it only applies for solids.
But I thought that in a photon-electron interaction either all the photons momentum or none of the photons momentum is given to the electron in the metal.
From the above principle I applied the conservation of momentum and einstein's photoelectric equation: Energy = Threshold Energy + Kinetic Energy of Electron, and I derived a relationship between threshold frequncy and wavelength of the the photon.
Does that make sense?
