Need a clie on how to build a Laboratory scale using strain gages
This discussion focuses on building a laboratory scale using strain gauges, specifically within a working range of 2 to 200 grams and an accuracy of at least 2 grams. The user intends to utilize a maximum of 6 strain gauges configured in a Wheatstone bridge format. Key recommendations include starting with the strain gauge datasheet for application hints and conducting online research on strain gauge bridges for further insights.
  • Understanding of Wheatstone bridge configuration
  • Familiarity with strain gauge specifications and datasheets
  • Basic knowledge of load cell design principles
  • Experience with electrical measurements and calibration techniques
  • Research strain gauge datasheets for application-specific information
  • Learn about Wheatstone bridge calculations and configurations
  • Explore load cell design principles for accurate weight measurement
  • Investigate calibration techniques for laboratory scales
Engineers, hobbyists, and researchers interested in designing and building precision laboratory scales using strain gauges.
n05tr4d4177u5
Need a help on how to go about building a Laboratory scale using strain gages
I need to build a scale with a working range of 2 to 200 gm, an accuracy of at least 2 gm, footprint of no more that 16 in sq, and use no more that 6 strain gages.
I believe I need to set up the strain gages in wheatstone bridge format. But that's about all i know. What kind of calculations do i need, where do i start, then what's the next step?
I'd start with the datasheet for the strain gauge. That should have some application hints on it. Otherwise, google strain gauge bridge, and you should get some good hits. Here's the first hit I got with that google:
http://zone.ni.com/devzone/conceptd.nsf/webmain/C83E9B93DE714DB08625686600704DB1?OpenDocument
9K
