Gas Cylinder Discharge Time: Solving for V2 Vent
  • Context: Undergrad
  • Thread starter Thread starter nampe
    Volume
The discussion revolves around a problem involving the discharge time of a gas cylinder with two vents, V1 and V2. Participants explore the mathematical relationships and physical principles that govern the emptying process of the cylinder under different vent configurations.
  • One participant, Pedro, presents a problem about a gas cylinder that empties in different times depending on whether one or both vents are open.
  • Another participant suggests that the volume of the cylinder is irrelevant for the calculations, proposing to assume a specific volume to facilitate the rate calculations.
  • Concerns are raised about the physical mechanisms involved in the emptying process, questioning whether a piston or external pressure influences the discharge rate.
  • A participant proposes an algebraic approach to solve for the discharge time using the rates of the vents, indicating that the problem is likely intended as a mathematical exercise.
  • Pedro shares a derived equation relating the times and sizes of the vents, leading to a calculated time for vent V2 alone.
  • Some participants challenge the assumption that the product of time and vent size is constant, questioning the underlying principles of the emptying process.
  • Further discussion includes the implications of pressure equalization and the conditions under which the cylinder would empty, with one participant suggesting that the proposed mechanism may lead to infinite discharge time under certain assumptions.
Participants express differing views on the physical principles governing the emptying process and the validity of the mathematical assumptions made. No consensus is reached regarding the mechanisms at play or the correctness of the derived equations.
Participants highlight the dependence on assumptions about the physical setup, such as the role of pressure and the nature of the vents, which remain unresolved throughout the discussion.
nampe
hi :
i have this question, which it reads pretty simple but I am trying to see if someone can walk me through the answer...
A gas cylinder has two vents, V1 and V2, for
discharge. The cylinder empties in 7 minutes when
only vent V1 is open. The cylinder empties in 3
minutes when both vent V1 and vent V2 are open. About
how many minutes will the cylinder take to empty if
only vent V2 is open?
the answer is in actual minutes...
thanks
pedro
Science news on Phys.org
nampe,
obviously it doesn't matter what the vessel's volume is. So you could just assume it's 100 litres or something, and calculate how many litres per minute go thru each vent.
You have to know how (why) it empties for the conditions of the vents being open. Is there a piston pushing the stuff out? Is it in an infinite negative pressure reservoir?
turin is right, but my guess is that this is meant as an algebra problem, not a physics problem. Is that correct?
In that case, the rates are:
V1 = 1/7 (tanks per minute)
V1 + V2 = 1/3
Solve for V2 and invert to get the time for Valve 2 alone.
thanks every one for your replies... i found the answer and here it is...Think about it like this. For a given cylinder, the product (time to empty) x (total vent size) should be constant. Basically, if you open two vents of the same size, it should take half the time to empty. So let's say V1 and V2 are the sizes (areas) of vents 1 and 2. Then,
7 * V1 = 3 * (V1 + V2) = T * V2
From the first part of the equation, you can solve for V1 in terms of V2. That will then allow you to solve the second half of the equation for T, which is your answer.
so using 7 * V1 = 3 * (V1 + V2) = T * V2, i am solving for the first part of the equation...
7 * V1 = 3 * (V1 + V2)... 7V1=3V1+3V2...V1=3V2/4...now u got to place 7 * V1= T * V2 to obtain T value
7*3V2/4= T*V2...V2=7*3V2/4/V2 which V2=7*3/4=5.25
this was a gre practice question... pretty interesting ehhh?!
thanks again
Why? Did you find this in the solution guide or something? The rate that the cylinder empties is a lot more intimately related to why it empties, than how it empties.
I assume that the tank empties because the gas inside is at greater than atmospheric pressure. When the valves are opened the tank pressure changes until the pressure in the tank is the same as the pressure outside the tank. This way it doesn't matter how the tank empties as long as the starting tank pressure is the same each time.
Jess
If inactive pressure equalization is what causes the tank to empty, then it will never be empty (unless you assume that the ambient can be at a negative absolute pressure). Even if we assume that what is meant is pressure equalization with the ambient, then this will still take an infinite amount of time according to the proposed mechanism of strict baromotivation (I think it is a decaying exponential).
  • · Replies 20 ·
  • · Replies 22 ·
  • · Replies 45 ·
