Why Do Different Observers Measure Varying Directions in Particle Motion?
  • Thread starter Thread starter fusi0n
    Relativity
The discussion revolves around the concept of relative motion in modern physics, specifically addressing how different observers measure varying directions of a particle's velocity in different reference frames. The original poster seeks clarification on why these differing measurements do not indicate an inconsistency in observations.
  • Conceptual clarification, Assumption checking, Exploratory
  • Participants explore the implications of relative motion on velocity measurements, questioning the nature of directionality in different frames. Some suggest that both observers' measurements can be valid due to the relative nature of motion, while others hint at the mathematical setup of the frames and the significance of Lorentz transformations.
The conversation includes various perspectives on the problem, with some participants offering hints and encouraging independent thought. There is an acknowledgment of the complexity of the topic, and while no consensus is reached, the discussion is productive in exploring different angles of the question.
Participants note the importance of understanding that absolute velocity cannot be measured, which implies that direction measurements can also vary between observers. There is mention of potential homework assignments that could reinforce these concepts through practice.
fusi0n
Hi all. I just started a modern physics course and I am having a difficult time conceptualizing the material right from the beginning. No homework yet..., but a question from the text reads:
Q. Since the velocity components of a moving particle are different in relatively moving frames, the directions of the velocity vectors are also different, in general. Explain why the fact that observers in S and S' measure different directions for a particle's motion is not an inconsistency in their observations.
I feel like if someone worked through this I could grasp the material better. As of right now I would say both observations are correct because the particle is being measured relative to each observer.
Thanks
You should try to think this through for yourself. I'm sure you are learning these facts: that measurements of length and time depend on the velocity of the frame doing the measuring. But there is a key difference between those two kinds of measurements. Hint: A moving clock will be measured to run slow no matter what direction it moves, but the length a moving object will only be measured differently in the direction of its motion.
what is velocity in differential form? the change of what with respect to what?
what kind of strange things are byproducts of the lorentz transformations?
i'm just learning special relativity too, hope that helps?
Now note they're saying in general. Mathematically speaking and usually, you try to set it up so the two frames have parallel x-axis' which means they do in fact have the same direction, but in general if S' is moving up or down at all, they won't. As for why it's not an inconsistency, I'm betting your book has a diagram with the lights and mirror clock thing, and if the mirror and light are moving you get that zigzag that forms the triangle that you can use to get the formula for time dilation. Well, in the moving frame they just see a light going back and forth like normal, in the stationary frame they see that zigzagging triangle, looking at the same thing, they see two different things(heh, that's so not worded right but you know what I mean)yet there is no inconsistency in their observations. See?
FusiOn,
you know the principle that
absolute velocity cannot be measured.
So now you realize what this implies: that
different observers don't have to agree
on the results of direction measurement either.
(but if needed, these can be "converted")
Would you feel better if they assigned a HW
where you practice converting a direction angle?
Even if the direction is not important?
  • · Replies 22 ·
  • · Replies 26 ·
