Understanding the Doppler Effect in Physics: Explained and Solved Questions
The discussion focuses on the Doppler Effect as it applies to sound waves and relative motion. When a brother catches a ball thrown by his sister, he measures a greater velocity if he runs toward her and a lower velocity if he runs away. In the case of sound, while the speed of sound remains constant at 343 m/s in air, the frequency perceived by the brother increases when he moves toward his sister, resulting in a higher frequency due to the Doppler Effect. The key takeaway is that the speed of sound is unaffected by the motion of the source or observer, but the frequency perceived changes based on their relative motion.
  • Understanding of the Doppler Effect in physics
  • Basic knowledge of sound wave properties (frequency, wavelength, speed)
  • Familiarity with relative motion concepts
  • Ability to perform basic calculations involving speed, frequency, and wavelength
  • Study the mathematical formulation of the Doppler Effect for sound waves
  • Explore the implications of the Doppler Effect in astronomy
  • Learn about the applications of the Doppler Effect in radar and medical imaging
  • Investigate how the Doppler Effect differs for light waves compared to sound waves
Students studying physics, educators teaching sound wave properties, and anyone interested in understanding the principles of the Doppler Effect and its applications in real-world scenarios.
andytran
this is from my physics assignment... after pulling half of my hair, i still couldn't figure it out...
my answer for part a) is greater and lower
and part b) is same and same...
not sure tho...
thx
4. Part a) A sister has a ball which she throws toward her brother. The ball is thrown with a velocity, v. The brother stands stationary and catches the ball. Now, if instead the brother is running toward his sister when he catches the ball, would he measure a greater or a lower velocity for the incoming ball (relative to himself)? What about if he is moving away from her when he catches the ball? Remember, velocity is relative. ( /1)
4. Part b) The brother is located some distance from his sister. Both are stationary. She shouts at him with a pure tone (say, 400 Hz). He measures that the velocity of sound (emitted from his sister) is 343 m/s when they are both stationary. They try this experiment a second time, but this time the sister runs toward her brother (he is still stationary). He perceives a higher frequency due to the Doppler effect. If he measures the speed of the sound, would he get the same velocity, higher, or lower than when she was stationary? Finally, what if the brother runs toward his sister, who is stationary. As before, she shouts at 400 Hz, and as before, he perceives a higher frequency. When he measures the speed of the sound from his reference frame, what does he get this time, higher, lower, or the same as when they were both stationary? ( /4) (Explain your answers. be careful – this question is tricky) ( /4)
a) should be easy- in fact the speeds add so running toward his sister the ball will have a greater speed (relative to the boy) and running away from his sister it will have lower speed (again, relative to the boy) as you say.
b) "Frequency" means how many cycles of the sound wave pass you in a second. That will depend on both how long the wave is and how fast it is moving (think of it like a long train passing while you sit in your car at the crossing).
If each wave has length l meters and is moving at v meters per second, then it will pass in l/v seconds or (inverting) you will see v/l cycles each second: frequency, f= v/l.
We are told that the sister shouts in a "pure tone" at 400 Hz (very impressive, by the way!) and the speed of sound is 343 m/s. Okay "f= v/l" gives 400= 343/l or l= 343/400= 0.8575 meters wavelength.
(I just noticed that the question doesn't ask for specific values so that calculation wasn't really necessary!)
The simple answer to this is that the speed of sound is the speed of the sound in the air- the speed relative to the air is constant. As long as the boy is stationary, relative to the air, it doesn't matter that the girl is running- the speed of the sound is the same. He perceives the sound wave as being "scrunched up"- with shorter wavelength- and so higher frequency.
The sound wave still has the same speed realtive to the air is still 343 m/s but now the boy is moving relative to the air. He would perceive the sound as having a higher speed relative to himself. He would now see the wavelength as being the same as when both were stationary but, since the speed of sound is higher relative to him, the frequency is higher.
thanks for your answer...
i understand now, dun have to pull my hair anymore hehehe..
