Noob: ratio between constant and variable?
The discussion revolves around the concept of expressing the ratio of individuals with a specific skill in a changing population. Participants explore how to accurately represent this ratio considering the dynamic nature of population growth and decline.
  • One participant questions how to express the ratio of individuals with a unique skill in a constantly changing population.
  • Another suggests modeling the ratio as a continuous function of time, using parameters like birth rate and the mathematical constant e.
  • A participant inquires whether the ratio can be expressed in common terms, such as a simple fraction like 1:6,500,000,000.
  • Discussion includes the idea that the ratio must be expressed as a function of time for accuracy.
  • One participant introduces the concept of population models using differential equations, referencing the Malthusian model and its limitations.
  • Another participant notes that the actual ratio is on the order of 10^-9 to 10^-8 and discusses the variability of demographic ratios over time, emphasizing the importance of including factors like births and migration.
Participants express differing views on how to represent the ratio, with some advocating for a time-dependent function while others seek a more straightforward numerical representation. The discussion remains unresolved regarding the best approach to express the ratio.
Limitations include the need for assumptions about population dynamics, the dependence on definitions of skill and population, and the unresolved mathematical steps in modeling population changes.
jimmie
OK, so I'm not a math major. :( or is it :) (I guess that's philosophy)
Anyway, here is what I'm stumped on.
Population. It is always changing.
So, let's say that only 1 person in the population has a particular skill that no other person has.
What would the correct ratio be of persons having that particular skill?
Can't be 1:6,400,000,000 or whatever the current population is, because by the time you finish reading this statement, the population has changed.
jimmie
Mathematics news on Phys.org
Because the population changes continuously, you can represent the ratio you desire as a continuous function of time. If b is the birth rate, P is the current population, and e is the constant 2.71828..., then the ratio could be modeled the following way:
[tex]Ratio at time t = P e^{-bt}[/tex]
Is it possible to express the ratio in common terms as with other ratios?
1:6,500,000,000 type of thing?
jimmie, the ratio has to be expressed as a function of time in order to be as accurate as can be.
Oh. Ok.
thanks
jimmie
A population model is actually a differential equation (like Crosson made an attempt).
A first order approach would be a linear differential equation, the malthusian population model (posited in 1798 by the British economist Thomas Malthus): P'(t)=rP(t), with P(0)=6,400,000,000; where P(t) is the number of people at a given moment, r is a growfactor (r>0 means growth, r=0 means constant, r<0 means decrease).
Your ratio would be (assuming no one else with that special skill comes onto play) 1/P(t).
Of course, the exponential growth is only acceptable over a short periods of time. Competition for food, local factors,... will tamper the growth of a population. A second order approach is a non-linear approach, the population model of Verhulst (1837):
P'(t) = eP(t) - sP(t)², P(0)=6,400,000,000; with s<<e.
The actual ratio is of the order 10-9 (well 10-8) so the ratio will be unchanged for quite a long period of time. (In the social sciences if you can get to + or - 5 percent, you are generally doing well. In epidemiological studies, I believe that they shoot for better accuracy.) Many ratios used in demographics and economics, labor force participation ratios, unemployment rates, proportion of US household with an income of $100,000, rates of household mobility, proportion of owned housing units and so forth can tend to vary with time. And, sometimes, it's the numerator that changes more than the denominator.Also, some of these ratios remain quite constant, like mobility rates (Mobility refers to moving from one dwelling unit to another). Indeed, to do things right, you need to include what's coming in -- births, migration -- and going out-- deaths and migration. In computer simulations, generally you use difference equations relating a state to it's plus and minus sources, which leads, in simplest form, to exponential variations. As the good Dr. points out, there are cases in which the plus and minus rates are population dependent. (For an exhaustive account of such models see the classic by M.S. Bartlett, An Introduction to Stochastic Processes, written in 1962, published by Cambridge University. It is still a very valuable text, in spite of its age.)
Regards,
Reilly Atkinson
  • · Replies 25 ·
