What are the Answers to Operational Amplifier Questions?
  • Thread starter Thread starter Clari
    Amplifier
The discussion revolves around operational amplifiers, specifically focusing on feedback resistance calculations and potential differences at specific points in a circuit. Participants are exploring the relationships between input and output voltages, as well as current calculations in the context of op-amp behavior.
  • Mixed
  • Participants discuss calculations related to feedback resistance and potential differences at points A and B in the circuit. There are attempts to verify the correctness of these calculations and to understand the underlying principles, such as Ohm's law and the behavior of ideal op-amps.
Some participants express uncertainty about their calculations and seek clarification on the reasoning behind certain steps. There is acknowledgment of correct answers, but also a recognition of potential misunderstandings regarding current calculations and voltage relationships. Guidance has been offered regarding the interpretation of input voltages and their impact on output voltage.
Participants are working under the constraints of homework assignments, which may limit the information available for discussion. There is an emphasis on understanding the circuit design and the operational principles of op-amps without providing direct solutions.
Clari
hi there,
i have two questions concerning operational amplifier which i can't figure out. i have tried them for hours, and finally get on a bit, yet i am not sure whether i have the answer right. :(
1a. What is the value of the feedback resistance in figure 1?
My ans: V_out/ V_in = 1+ R_f/ R_in
30/ 6 = 1+ R_f/ 10 x 10^3
R_f = 40000 ohm
2. In figure 2, Assume the op amp does not saturate, find the potentials at A and B.
At A, the current = 3.2 x 5k = 0.64 mA
At B, the current = 2.8 x (5k+15K) = 0.14 mA
Total current = 0.64 + 0.14 = 0.78 mA
Potential at A = (0.78 -0.64) x 15k = 2.1V
Potential at B = 0.14mA x 15k = 2.1V
please help me. ^^
Clari said:
hi there,
R_f = 40000 ohm
please help me. ^^
Question 1 is correct.
You also got the right answer for the second one, but I'm not sure why you did what you did.
If your resistances were labeled from left to right, with the top resistors first, you'd have R1=5K, R2=15K, R3=5K, R4=15K.
For an ideal op amp, the inverting input (-) and the non-inverting input (+) have the same voltage. Once you solve for the potential at B, you've solved for the potential at A.
Your currents are wrong, however. B is correct, but A is wrong. To find the current at A, you need (Vin - Va)/R1.
(3.2V-2.1V)/5k = .22mA
The rationale is that 1.2 volts were dropped across R1 (2.1 is 1.2 Volts lower than the input voltage). Per Ohm's law, the current through the resistor is V/R.
It's the current at A that will give you your output voltage:
Va-(.22mA*R2) = 2.1 - (.22mA*15K) = 2.1 - 3.2 = -1.2
Rationale is the same as before. You're still using Ohm's law: V=RI. You're dropping 3.2 volts, so the output voltage has to 3.2 volts lower than point A.
If you subtracted your input voltages (3.2 - 2.8) and multiplied by the inverting gain (-R2/R1), you'd get the same answer for the output voltage (but might not understand why). Or if you subtracted your input voltages (2.8 - 3.2) and multiplied by the non-inverting gain {(R1+R2)/R1}*{R4/(R3+R4)}, you'd get the same answer for the output voltage.
Hello BobG, i can figure it out now. Thank you very much. Your help is greatly appreciated. :approve: well, i have also tried the alternative method before but i don't know why the two voltages have to subtracted from each other. :smile:
That's the goal of the circuit. It was designed so the output would depend on the difference between the two inputs. You can also design opamp circuits to sum two or more voltages, integrators, differentiators, etc.
