Complex Plane Dimension Number
The discussion centers on the dimensionality of the complex plane in relation to physical theories, particularly the distinction between mathematical abstractions and physical dimensions. Terry Giblin highlights that complex numbers, represented as z = x + iy, introduce an imaginary axis, often referred to as the '5th dimension.' However, the conversation clarifies that the complex plane is a mathematical construct, while the 11 dimensions of brane theory pertain to physical dimensions. Visualization of complex functions like f(z) = z^(2/3) typically requires a three-dimensional surface plot, as the domain and range are both two-dimensional.
  • Understanding of complex numbers and their representation (z = x + iy).
  • Familiarity with the concept of dimensions in physics and mathematics.
  • Knowledge of complex functions and their visualization techniques.
  • Basic principles of brane theory and its implications in physics.
  • Research the visualization techniques for complex functions, focusing on surface plots.
  • Study the implications of brane theory in modern physics, particularly the concept of dimensions.
  • Explore the mathematical properties of complex numbers and their applications in various fields.
  • Investigate the differences between physical dimensions and mathematical abstractions in theoretical physics.
Mathematicians, physicists, and students interested in the intersection of complex number theory and dimensional analysis in theoretical physics.
Terry Giblin
What dimension between space-time and 11 Dimensions is allocated to the complex plane 'visualized' and used in complex number theory?
Complex numbers are used in every branch of maths and physics, based on an imaginary complex plane, z = x +iy where y is an imaginary axis and i^2=-1. - It's another Dimension, the imaginary '5th' dimension.
In the current theories, what is name or number of is this dimension apart from the obvious 'imaginary dimension' - what number is it given?
Regards
Terry Giblin
You seem to be mixing up several concepts in physics and mathematics
that are different.
To properly visualize a complex function like [tex]f(z) = z^\frac{2}{3}[/tex],
you would like 4 dimensions because the domain of the function is two-dimensions
and so is the range. This can't be done easily, so people usually plot |f(z)| which
is a scalar against z which is two dimensional. The result is a three-dimensional
surface plot.
You are mixing up two different (although similar in some ways) concepts. The 11 dimensions of brane theory are physical dimensions, like space and time. The complex plane is a mathematical abstraction. One obvious difference is that for physical dimensions the numbers are in units of length or time, which can be changed (like from feet to meters). The numbers in the complex plane are absolute, e.g. 1 is 1 and nothing else - there is no concept of feet or seconds.
  • · Replies 19 ·
  • · Replies 24 ·
