What Causes Discrepancies in Calculating Shearing Stress in a Circular Shaft?
The discussion centers on calculating the maximum shearing stress in a circular shaft subjected to a torque of 120 ft-lb. The correct formula for shearing stress is given as τ = Tr/J, where T is torque, r is the radius, and J is the polar moment of inertia. The initial calculation yielded an incorrect value of 1448 psi due to a failure to convert torque units from ft-lb to in-lb. After correcting the unit conversion, the accurate maximum shearing stress is determined to be 17.39 ksi.
  • Understanding of shearing stress calculations
  • Familiarity with torque and its units
  • Knowledge of polar moment of inertia (J) for circular shafts
  • Basic unit conversion techniques
  • Review the derivation of the polar moment of inertia for different cross-sectional shapes
  • Learn about unit conversions in mechanical engineering, specifically for torque
  • Explore advanced shearing stress analysis in composite materials
  • Investigate the effects of varying shaft lengths on shearing stress calculations
Mechanical engineers, students studying mechanics of materials, and professionals involved in structural analysis of shafts and rotating machinery.
Pepsi24chevy
Hey guys, I got a problem that goes like: A shaft with a circular cross section is subjected to a torque of 120ft-lb. Its shaft's diameter is 0.750 in and its length is 15 in., determine the maximum shearing stress.
I did the following: I tried to use shearing stress = Tr/J in which i plugged in as followed (120*.750/2)/(pi/32)*.750^4 and i get 1448, but the answer should be17.39ksi. I assume i am not getting the right answer because I am not factoring in the length but I am not sure. Any help is appreciated, thanks
nm, i figured it out, Stupid me forgot to convert the ft-lb to inch-lb.
14K
10K
10K
