Understanding the Maclaurin Series of cos(x) for Use in Functions
The discussion focuses on the Maclaurin series of cos(x) and its application in deriving the series for the function h(x) = (cos(3x) - 1)/x^2. The formula for the Maclaurin series is f(x) = ∑(k=0 to ∞) (x^k/k!) f^(k)(0). The series for cos(x) is expressed as cos(x) = ∑(k=0 to ∞) (x^(2k)/(2k)!)(-1)^k, where odd terms are eliminated. The transformation of the known series into the form of h(x) is essential for simplification and analysis.
  • Understanding of Maclaurin series and Taylor series expansions
  • Familiarity with calculus concepts such as derivatives and limits
  • Knowledge of trigonometric functions and their series representations
  • Basic skills in algebraic manipulation and simplification of series
  • Study the derivation of the Maclaurin series for sin(x) and its applications
  • Explore the use of Taylor series in approximating functions beyond trigonometric functions
  • Learn about convergence criteria for power series and their implications
  • Investigate the application of complex contour integration in deriving series
Mathematicians, students of calculus, and anyone interested in advanced series expansions and their applications in function analysis.
Muzly
I've looked at a number of explanations for the Maclaurin series of cos(x) yet none have given an easily understood answer, i was wondering if anyone has a way of explaining it when it is used as only a part of a function
eg. use that Maclaurin series of cos(x) to obtain the Macalurin series for
h(x)=(cos(3x)-1)/x^2
The formula for Maclaurin series is
[tex]f(x)=\sum_{k=0}^\infty \frac{x^k}{k!}f^{(k)}(x)[/tex]
as can be easily derived several ways
-integration by parts
-formal operator manipulation
-matching derivatives at zero
-complex contour integration
This can be applied to cos(x) as
[tex]\cos(x)=\sum_{k=0}^\infty \frac{x^k}{k!}\cos^{(k)}(0)=\sum_{k=0}^\infty \frac{x^k}{k!}\cos(k\pi/2)=\sum_{k=0}^\infty \frac{x^{2k}}{(2k)!}(-1)^k[/tex]
where the index is changed in the final step to indicate odd terms are 0
Often a known Maclaurin series can be used to find a closely related one.
Just apply the known series
[tex]h(x)=\frac{1}{x^2}\left(\sum_{k=0}^\infty \frac{(3x)^{2k}}{(2k)!}(-1)^k-1\right)[/tex]
simplify that into standard form.
