JM00404
- 7
Consider the equation [tex]Ly'+Ry=E\sin(\omega x)[/tex] , where [tex]L,R,E,\omega[/tex] are positive constants.
1) Compute the solution [tex]\phi[/tex] satisfying [tex]\phi(0)=0 .[/tex]
2) Show that this solution may be written in the form [tex]\phi(x)=\frac{E\omega L}{R^2+\omega^2L^2}e^{-Rx/L}+\frac{E}{\sqrt{R^2+\omega^2L^2}}\sin(\omega x-\alpha) ,[/tex]
where [tex]\alpha[/tex] is the angle satisfying [tex]\cos (\alpha)=\frac{R}{\sqrt{R^2+\omega^2L^2}}[/tex] , [tex]\sin(\alpha)=\frac{\omega L}{\sqrt{R^2+\omega^2L^2}}.[/tex]
I have already solved part (1) of this problem but am having some difficulty converting the solution that I computed for part (1) to that which will allow me to answer part (2). A summary of the work that I did to solve part (1) can be found immediately following this sentence.
[tex]Ly'+Ry=E\sin(\omega x) \iff y'=\frac{Ry}{L}=\frac{E\sin(\omega x)}{L}[/tex] .
[tex]Let \ a(x)=R/L \implies \int a(x)dx=Rx/L .[/tex] [tex]\therefore e^{\int a(x)dx}=e^{Rx/L}.[/tex]
[tex]e^{Rx/L}\left[y'+\frac{Rx}{L}\right]=e^{Rx/L}\left[\frac{E\sin(\omega x)}{L}\right] \implies \left(e^{Rx/L}y\right)'=\frac{E}{L}\left[e^{Rx/L}\sin(\omega x)\right][/tex]
[tex]\implies \int \left(e^{Rx/L}y\right)'dx=\frac{E}{L}\int e^{Rx/L}\sin(\omega x)dx=\frac{E}{L}\left[\frac{1}{(R/L)^2+\omega^2}\right]\left[e^{Rx/L}\right]\left[\frac{R}{L}\sin(\omega x)-\omega\cos(\omega x)\right]+C[/tex]
[tex]=E\left[\frac{R\sin(\omega x)-L\omega\cos(\omega x)}{R^2+\omega^2L^2}\right]e^{Rx/L}+C \implies y=\phi(x)=E\left[\frac{R\sin(\omega x)-L\omega\cos(\omega x)}{R^2+\omega^2L^2}\right]+Ce^{-Rx/L}.[/tex]
[tex]\phi(0)=E\left[\frac{0-L\omega}{R^2+\omega^2L^2}\right]+Ce^0=-E\left[\frac{0-L\omega}{R^2+\omega^2L^2}\right]+C=0 \implies C=E\left[\frac{0-L\omega}{R^2+\omega^2L^2}\right] .[/tex]
[tex]\therefore \phi(x)=E\left[\frac{R\sin(\omega x)-L\omega\cos(\omega x)}{R^2+\omega^2L^2}\right]+E\left[\frac{L\omega}{R^2+\omega^2L^2}\right]e^{-Rx/L}.[/tex]
What I cannot seem to figure out how it is that I am supposed to convert the first component of the solution, [tex]E\left[\frac{R\sin(\omega x)-L\omega\cos(\omega x)}{R^2+\omega^2L^2}\right][/tex] , into [tex]\frac{E}{\sqrt{R^2+\omega^2L^2}}\sin(\omega x-\alpha)[/tex] as is written in part (2) of the above problem. It would be appreciated if someone could provide me with some additional insight into how to complete part (2) (it appears that I am probably not seeing what it is that I need to do in order to solve the remainder of the problem). Prompt responses are greately appreciated. Thank you for your time.
