Solve Time Delay Equations: Derive (6) and (7) from Mackey-Glass
The discussion revolves around deriving equations related to the Mackey-Glass model, specifically focusing on the eigenvalue equations (6) and (7) as referenced from a webpage. Participants express uncertainty about the derivation process and the implications of these equations in the context of delay differential equations (DDEs).
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss substituting assumed solutions into the linearized equation and question how to derive the eigenvalue equations. There are mentions of integrating over intervals and using previous solutions as delay functions in the ODE.
Some participants suggest methods for approaching the problem, such as integrating in intervals and using numerical solutions. There is an acknowledgment of the complexity involved, and while some guidance has been offered, multiple interpretations and approaches are still being explored.
Participants note the requirement of an initial function for DDEs rather than a single initial point, which adds to the complexity of the problem. There is also a mention of the potential application of these equations in modeling biological processes, such as leukemia.
bor0000
i need to solve an equation of the form (5) from this webpage http://chaos.phy.ohiou.edu/~thomas/chaos/mackey-glass.html
first it asks to "derive the corresponding eigenvalue equation"- i presume they mean to derive (6)? if so, i don't know how they get it.
and then they ask for something similar to deriving (7), i have no idea how to proceed... thanks.
Jesus dude, I gotta' get that book! One way to proceed of course is . . . to check out the book from a library. Deriving the eigenvalue equation is just substituting the assumed solution:
[tex]y(t)=e^{\lambda t}[/tex]
into the "linearized equation:
[tex]y^{'}=\alpha y+\beta y_{\tau}[/tex]
remembering [itex]y_{\tau}=e^{\lambda(t-\tau)}[/tex]<br /> <br /> Deriving (7) I assume means to solve for lambda in:<br /> <br /> [tex]\lambda=\alpha+\beta e^{-\lambda \tau}[/tex]<br /> <br /> assuming lambda is complex and determining under what conditions the real part is less than zero (not sure though, just my assumption). Really, this would take me days to fully study, a week maybe. But very interesting. Thanks. <img src="https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f642.png" class="smilie smilie--emoji" loading="lazy" width="64" height="64" alt=":smile:" title="Smile :smile:" data-smilie="1"data-shortname=":smile:" />[/itex]
You know we can make progress with this. First put it into standard DDE form:
[tex]\frac{dW}{dt}=aW(t-\tau)\frac{k_1}{k_1+[W(t-\tau)]^n}-bW[/tex]
That gives the rate of change of the density of white blood cells circulating in the blood as a function of the current density as well as the density at a previous time. This is doable. First thing to note that with DDEs, rather than an initial point given as the initial condition, an initial function has to be given in the interval:
[tex](-\tau,0)[/tex]
So we'll call that initial condition [itex]f_1(t)[/itex]
Now, in the interval [itex](0,\tau)[/itex], we have a regular ODE:
[tex]\frac{dW}{dt}=af_1(t-\tau)\frac{k_1}{k_1+[f_1(t-\tau)]^n}-bW[/tex]
Which we can integrate from 0 to [itex]\tau[/itex]. We'll call that function [itex]f_2(t)[/itex]. Now, plug that into the DDE:
[tex]\frac{dW}{dt}=af_2(t-\tau)\frac{k_1}{k_1+[f_2(t-\tau)]^n}-bW[/tex]
and integrate from [itex]\tau[/itex] to [itex]2\tau[/itex]. See what's happening? Keep doing that. It get's messy. And how can this DDE help model the onset of lukemia? Think I'll spend some time on it.
Here's an example.
[tex]\frac{dy}{dt}=\frac{0.2 y(t-14)}{1+y(t-14)^{10}}-0.1y(t);\quad y(<0)=0.5[/tex]
As I stated earlier, we'll integrate in intervals of the delay using the previous solution as the delay functions in the ODE. Here is the first interval in Mathematica:
[tex]f_0[t]=0.5;[/tex]
[tex]\text{sol1=NDSolve}[{y^{'}==\frac{0.2 f_0[t-14]}{1+f_0[t-14]^{10}}-0.1y(t),y[0]=f_0[0]},y,\{t,0,14\}][/tex]
[tex]f_1[t\_]\text{:=Evaluate[y[t]/.Flatten[sol1]];}[/tex]
Here's the second one:
[tex]\text{sol2=NDSolve}[{y^{'}==\frac{0.2 f_1[t-14]}{1+f_1[t-14]^{10}}-0.1y(t),y[14]=f_1[14]},y,\{t,14,28\}][/tex]
[tex]f_2[t\_]\text{:=Evaluate[y[t]/.Flatten[sol2]];}[/tex]
Note how I substituted [itex]f_1(t-14)[/itex] into the ODE to represent the delay for the second interval. Here's the third interval:
[tex]\text{sol3=NDSolve}[{y^{'}==\frac{0.2 f_2[t-14]}{1+f_2[t-14]^{10}}-0.1y(t),y[28]=f_2[28]},y,\{t,28,42\}][/tex]
[tex]f_3[t\_]\text{:=Evaluate[y[t]/.Flatten[sol3]];}[/tex]
And so on for each interval. A plot of the first three intervals is attached. Is there another way to do this? Should I go over to the ODE forum and ask as this isn't my homework?
thank you!
  • · Replies 58 ·
