How Can We Understand Iterated and Double Limits in Complex Variables?
  • Thread starter Thread starter hanson
    Limit
The discussion revolves around understanding the concepts of "iterated limits" and "double limits" in the context of complex variables, particularly in relation to the Cauchy-Riemann equations. Participants are exploring how these limits behave when approaching a point in the complex plane.
  • Conceptual clarification, Assumption checking, Exploratory
  • Participants are attempting to differentiate between iterated limits and double limits, questioning the meaning of a double limit and how it relates to paths taken in the complex plane. There are inquiries about specific paths and examples, as well as the implications of path independence for limits.
The discussion is active, with participants raising questions and offering insights about the nature of limits in complex analysis. Some guidance has been provided regarding the relationship between iterated limits and double limits, but there is no explicit consensus on the definitions or implications of these concepts.
Participants are grappling with the definitions and implications of limits in the context of complex functions, particularly regarding the conditions under which limits are considered to exist. There is an emphasis on the need for path independence in the evaluation of limits.
hanson
Hello!
I am confused about things about "iterated limit" and "double limit"
I am doing something about complex variables, and learning to derive the Cauchy-Riemann Equation.
The concept of "iterated limit" to me is that, supossing 2 independt variables x&y, it is taking the limit either x first then y or y first then x. Geometrically, it is representing two paths to approach the right destination, right?
But I can't really visualise how "double limit" really work.
What is a double limit? I am told that it is "x and y go togather in any manner"
What does it mean?
I can think of some cases that x and y will approach the destination togather.
Say, the path is y=mx as x->0. In this case, x and y will approach to 0 togather. So, is this a double limit?
If this is, there is also a problem.
There is a statement that "the limit, representing the derivative of a complex function, must exist as a double limit for delta z= delta x+i(delta y) approaching zero."
I don't see why the term "double limit" is used here.
To me, the complex derivative exists when all double limits and all iterated limits gives the same value so that the limit can be said of being independent of any paths. Am I correct?
hanson said:
Hello!
What does it mean?
You are correct. The Cauchy-Riemann equations simply impose the restriction that the limit is the same whether [itex]\Delta z[/itex] appraoches zero along the real and imaginary axis. It can be proven that this is enough to guarantee that the limit is the same along all paths in the complex plane.
In terms of a double limit in general, that could mean something like:
[tex]\lim_{\substack{x\rightarrow 0\\y\rightarrow 0}} x^y=1[/tex]
[tex]\lim_{\substack{y\rightarrow 0\\x\rightarrow 0}} x^y=0[/tex]
This really is not the same thing as delta z approaching zero, having real and imaginary parts. z is only one number, and that is how it is treated in the analytic functions of complex analysis. You could write a real number in terms of rational and irrational parts, like: [itex]x = a + b\sqrt{2}[/itex] Then you could take the limit as x approaches zero as only one number, because in real analysis we do not treat functions that perform different operations on the rational and irrational parts. Just so, in complex analysis we deal with functions that treat z as one indivisible entity.
don't we need to specific a path for double limit?
Don't we need to specify a path for double limit?
like y=mx, x->0, y->0?
And how can the two examples of double limit be calculated?
Well, the limit only exists if it is "path independent"
let us fix that we're taking a limit as x,y both tend to 0 of some function f(x,y), let us further suppose that we want to show that limit is zero
then we need to show that for all e>0 there is a d>0 such that for all |(x,y)|<0 that |f(x,y)<0 where | | means distance eg the euclidean distance from the origin.
it is natrually easier to show that a limit does not exist by showing two different paths that have different limits.
however this is a situation when we are talking about (x,y) tends to zero.
this strictly different from a double limit
lim x tends to 0 of lim y tends to 0 of f(x,y)
  • · Replies 27 ·
  • · Replies 19 ·
