dand5
- 28
I have a quick question about integration after a change of variables has been made.
Suppose there is a function [tex]R(t_{1},t_{2})[/tex] that actually just
depends on the difference [tex]t_{1} - t_{2}[/tex]. The goal is then to
simplify the following integral:
[tex] \frac{1}{T^{2}}\int^{T}_{0}\int^{T}_{0} R(t_{1},t_{2}) dt_{1}dt_{2}[/tex]
by using the substitution [tex]t_{1}' = t_{1}[/tex] and [tex]t_{2}'= t_{1} - \tau[/tex].
A straight substitution yields:
[tex] \frac{1}{T^{2}}\int \int^{T}_{0} R(\tau) dt_{1}'(dt_{1}' - d\tau)[/tex]
I am uncertain about two things:
1) the integration bounds on the outer integral after the substitution has been made
2) whether or not [tex]dt_{1}'[/tex] in the outer integral is zero since
[tex]dt_{1}[/tex] is held constant when integrating over [tex]dt_{2}[/tex] before the substitution was made.
As a heads up the final result is supposed to be:
[tex] \frac{1}{T^{2}}\int^{T}_{-T}\left(T-\left|\tau\right|\right)R(\tau) d\tau[/tex]
Thanks in advance for any responses.
