Enthelpy, thermal energy, and kinetic vs. potential energy
The discussion revolves around the concept of enthalpy and its relationship to energy, particularly in the context of thermal and kinetic versus potential energy. Participants are exploring the definitions and implications of these concepts within thermodynamics.
  • Conceptual clarification, Assumption checking, Mixed
  • The original poster attempts to clarify their understanding of enthalpy, questioning whether it is a measure of potential energy or kinetic thermal energy. They raise points about the first law of thermodynamics and the nature of energy transformations.
  • Some participants question the definitions and relationships between internal energy, enthalpy, and the work done during reactions, suggesting a need for clearer distinctions.
  • Others suggest reconsidering the interpretation of kinetic energy and its relation to temperature, noting that the relationship is not always straightforward.
Participants are navigating complex thermodynamic concepts, and there are indications of confusion regarding the definitions and relationships between different forms of energy. The original poster expresses a desire for confirmation of their understanding, highlighting the educational context of the discussion.
arkabas
Hi everyone,
None of my professors seem to be able to clearly explain what enthalpy is and its relation to energy. If possible, please confirm or correct my reasoning below:
Energy is an abstract (yet quantifiable) term that describes the capacity to cause a change (do work) in a system (e.g., push something or cause atoms to stay close together in a molecule). Energy can exist in many forms including thermal (kinetic) and chemical (potential).
Enthalpy (H) is NOT a form of energy, but instead it is a measure of the amount of energy stored (as potential energy?) in a system (e.g., energy in all the chemical bonds of a molecule). Since it is practically impossible to measure potential energy (all forms of potential energy, right?), we must look at released energy (kinetic energy?). Because of natural random and statistacly probable entropy, when no energy is applied to keep order in a system, it is released spontaneously as kinetic thermal energy, right? And this can be quantified by heat/temperature change. And this is what enthalpy (H) measures. Correct?
Ok, some more thoughts. Enthalpy (H) is the measure of kinetic thermal energy, correct?? This is useful because it shows how much energy was originally stored as potential energy in a system, right? Sort of like working backwards to understand the original conditions.
Ok, a few more ideas. First law of thermodynamics states that all energy can be interconverted (aka transduced). HOWEVER, thermal energy (and I suppose all types of kinetic energy, right?) are a unique case because they OFTEN (not always) are unable to be transduced back into other forms of "useful to do work" energy. This is because kinetic energy naturally dissipates (spreads out) and, since the universe is still expanding, it dissipates out and is often "lost" because it fails to concentrate. In other cases, kinetic thermal energy can be used to power stuff (like a piston in a car, I think).
Super sorry for the length, but I am very curious about this stuff. Please tell me if my reasoning makes sense and/or where I went wrong.
Thanks in advance.
Not a single response?
This seems to be a little confused. The energy released by a reaction is the change in the internal energy. However, most reactions people look at take place at constant pressure rather than constant volume. This means that the volume of a system may change durring the course of a reaction, causing the system to do expansion work on the surroundings (or have work done on it if it contracts) This means that the heat realeased by the reaction will not be equal to the change in the internal energy, because some of the energy will go to work of expansion. However, look at the change in enthalpy, when no other work modes are present:
[tex]H\equiv U + PV[/tex]
because no other work modes are present, dU can be expressed as:
[tex]dU=dQ + dw=dQ -pdV[/tex]
Now, the change in enthalpy is:
[tex]dH = dU + PdV +VdP= dQ -PdV +PdV -VdP[/tex]
The process takes place at constant P, so:
[tex]dH=dQ[/tex]
So this is why the enthalpy is often considered: the change in enthalpy is the heat of the reaction, when carried out at constant P.
No, the internal energy shows how much energy was stored in the system.
Kinetic energy is not heat. Kinetic energy in thermodynamics refers to energy resulting from the motion of the center of mass of a macroscopic object. Also,it is not, in general true that the more kinetic energy molecules contain, the higher the temperature. For a perfect gas in the ground state the temperature is proportional to the average kinetic energy of the particles, but this will not always be the case. A sample of matter with molecules at a lower average kinetic energy than another sample can still have a higher temperature if it has a higher proportion of molecules in an excited state, for intance.
it is much easier to consider enthalpy as a form of energy, as explaned in the attachment.
unfortunately the attachment doesn't show. I try it again.
I have a problem with a 'security token', whatever that may be.
Well, 3rd try. Looks good this time: this attachment is about enthalpy.
  • · Replies 58 ·
  • · Replies 30 ·
