Problem on Potential of Sphere
  • Thread starter Thread starter echau
    Potential Sphere
The discussion revolves around calculating the electric potential both inside and outside a uniformly charged sphere of radius R and total charge Q. Participants are exploring the relationships between electric field and potential in this context.
  • The original poster attempts to determine the potential inside and outside the sphere, noting the potential outside for r > R and seeking guidance on the potential for r < R. Some participants suggest calculating the electric field inside as a starting point for finding the potential.
Participants are actively engaging with the problem, with some providing insights into the relationships between electric field and potential. There is a recognition of the need to integrate the electric field to find the potential, and a few participants have shared their reasoning and approaches without reaching a consensus.
There is an emphasis on the additive constant for the potential inside the charged sphere to ensure continuity at r = R. The original poster expresses uncertainty about the integration process and the relationship between the potentials inside and outside the sphere.
echau
Hi,
Could somebody please help me on a problem regarding Potential?
Calculate the potential inside and outside a sphere of radius R and charge Q,in which the charge is distributed uniformly throughout. [Hine: The additive constant for the potential inside the charged sphere must be chose so that the two potentials inside and outside, agree at r=R]
So far, I know that V(outside)=Q/(4*PI*e0*r) when r>R.
How would I find the V(outside) when r<R?
The answer given in the back of the book is V=[Q/(8*PI*e0*R)][3-(r/R)^2]
I have no idea how to obtain it.
Also how would I go about finding the V(inside) for when r>R, and r<R?
Any help would be greatly appreciated!
You seem to be a bit confused. The potential "outside" refers to r>R while the potential "inside" refers to r<R. Your outside potential looks good. In order to find the inside potential perhaps you should begin by calculating the electric field inside (r<R) ...
The potential due to a thin spherical shell inside the shell is same as that on the surface.
Consider a point P at distance r (< R) from the center of the sphere. The sphere can be considered as a solid sphere of radius r, and a hollow sphere of inner radius r and outer radius R. Potential at point P is due to both.
1 Due to inner sphere and
2 due to outer part.
For first calculate charge and solve as on sphere of radius r.
For second consider a thin shell of radius x and thickness dx (R > x > r) calculate charge dq on the shell, potential at P due to this charge is dq/4*pi*e0*x
Integrate this for x = r to x = R
add the two potentials.
Hope this much is sufficient.
okay so the Electric Field inside is = (Q/4*PI*e0)(r/R^3). to find Potential, what would i do?
After i find this potential, i add it to the potential outside to get the total?
Thanks for all the input guys!
ah! nevermind. i got it!
first i had to find the electric field inside and integrate it, since dV=-E ds
I just integrate it from the interval [R,r] and that gives me the answer!
Thanks for all the help!
  • · Replies 43 ·
  • · Replies 17 ·
