Force & Tension: Solving 2 Problems
  • Thread starter Thread starter BriannaUND
    Force Tension
The discussion addresses two physics problems involving force and tension. The first problem calculates the average force acting on a 0.2 kg ball dropped from a height of 10 m, resulting in a gravitational force of 1.96 N and a need to determine the normal force exerted by the sand. The second problem involves a pulley system with a 3.0 kg block on an incline and a 2.5 kg hanging block, where the calculated tension of 3 N is incorrect; the correct tension is 21 N, factoring in gravitational forces and net acceleration. Key calculations involve using kinematic equations and understanding forces in a pulley system.
  • Understanding of Newton's laws of motion
  • Familiarity with kinematic equations
  • Knowledge of gravitational force calculations
  • Basic principles of tension in pulley systems
  • Study the concept of normal force and its calculation in different scenarios
  • Learn about energy conservation principles in physics
  • Explore advanced kinematic equations for motion under gravity
  • Investigate the dynamics of pulley systems and tension calculations
Students studying physics, educators teaching mechanics, and anyone interested in solving problems related to forces and motion in real-world applications.
BriannaUND
I am having some trouble with two problems- thanks for any help!
71) A .2kg ball is dropped from 10 m above the beach, leaving an impression in the sand 5.0 cm deep. What is the average force acting on the ball by the sand?
So far I have converted 5.0cm to .05m. I calculated Fg= .2 kg (9.8m/s2) = 1.96 N. Now I am confused as to how I should calculate the normal force of the sand.
73) On an inclined plane (with angle of 37 degrees) a pulley is holding block m1 on the incline and block two is hanging on the other side. The weights of the blocks are m1= 3.0kg, m2= 2.5kg. What is the tension in the string if the acceleration is 1.2 m/s2?
I calculated T= m2a = (2.5kg)(1.2m/s2) = 3 N but the answer in the back of the book says it should be 21 N?
Thanks again for the help- I really appreciate it!
73: your 3N is the TOTAL (net) Force.
gravity contributes about 25N
and the string has to cancel all but 3N of it.
72: it falls 10m from rest : ½ at^2 to find t,
then get v = a t just before hitting the sand.
The Force by the sand has to cangel gravity
and have enough left over to "decelerate" it.
Do you know energy? otherwise, v^2 = 2ax.
