Thread Closed
MI String
Share Thread Thread Tools
Sep20-05, 12:45 PM   #1
MI String
I don't know if you have encountered this problem in Logic and Mathematics. Anyway, you may try this:
You are given with an initial string of MI.
Here are the rules:
i) If you have a string that ends with I you can add a U
ii) If you have an Mx, (i.e., an a string that starts with an M, with other characters succeeding it) you can double the characters succeeding the M, i.e., you may lengthen your string by writing Mxx
ii) If you have an III part on your string, you may replace it with a U
iv) If you have a UU in your string, you can drop this altogether, i.e., starting with an MUUU, you can drop the UU, to get MU.
Now, the question is: Could you produce a string containing the characters, MU? (without of course trespassing the bounds of the rules)
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Bird's playlist could signal mental strengths and weaknesses
>> Minus environment, patterns still emerge: Computational study tracks E. coli cells' regulatory mechanisms
>> Bacterium uses natural 'thermometer' to trigger diarrheal disease, scientists find
Sep20-05, 04:37 PM   #2
YES!
initial string "MI"
(rule 2) -> "MII"
(rule 2) -> "MIIII"
(rule 3) -> "MUI" : this string contains the characters MU !
But it's impossible to get the string "MU" as final result.
Sep21-05, 07:32 AM   #3
I am sorry. May I rephrase the question with:
Could you produce a string containing exactly the characters, MU?
Sep21-05, 08:44 AM   #4
Recognitions:
Homework Helper Homework Help
MI String
Quote by croxbearer
Obviously not, since you can never get a string that does not contain at least one I.
Proof:
Consdier how the various operations alter the number of I's mod 3:
1,3, and 4 do not change it at all, and 2 multiplies the total number of I's by two.
Thus you cannot get from a string that has a number of I's that is not zero mod 3 to one that is. Specificall you cannot get from a string that contains one I to one that contains zero.
Sep21-05, 10:28 AM   #5
You can double the x where [tex]M_x[/tex]
3I is equal to U
[tex]\frac{2^n}{3}[/tex]
You are doomed to end up with 1 "I" remaining..
Sep21-05, 03:28 PM   #6
It is possible to get MIIIII (5 I's) so why shouldn't it be possible to get more numbers?
mi->mii->miiii->miiiiiiii->miiiiiiiu->miiiiiuu->miiiii
Sep21-05, 04:16 PM   #7
OK I think i see it now, It seems to be impossible to get to 3 from 1 by doubling, i can get any number mod 3 = 1 or 2.
Sep21-05, 05:20 PM   #8
Oh i was trying to say minimum # of I can only be 1, i didn't mean to rule out "2"
Thread Closed
Thread Tools
Similar Threads for: MI String
Thread Forum Replies
Do string th. calculate string decay rates? Beyond the Standard Model 0
quantizing a string in string theory Advanced Physics Homework 1
[SOLVED] [String-schools] String Vacuum in Trieste 2006 Beyond the Standard Model 0
Introductory Interactive Online String Theory Seminar at the String Coffee Table Beyond the Standard Model 0
