Determining Quadratic and Cubic Functions with Integral Coefficients
  • Thread starter Thread starter Dough
    Calculus Gr
The discussion revolves around determining the forms of a quadratic function and a cubic function, both with integral coefficients, based on given properties and conditions. The first question involves a quadratic function f(x) with specific roots and a value at a certain point, while the second question concerns a cubic function g(x) with its own set of roots and a value at another point.
  • Participants explore the general forms of quadratic and cubic functions, discussing how to express the functions based on given roots and factors. There are attempts to derive equations from the provided conditions, such as substituting values into the function forms.
Some participants have made progress in understanding the problem and have shared their attempts at formulating the functions. There is a mix of success and frustration, with some expressing confidence in their understanding while others indicate they are still struggling with the details. Guidance has been offered regarding the structure of the functions and how to utilize the given information effectively.
Participants note potential errors in their calculations and the challenges of working with integral coefficients. There is also mention of homework constraints, as some participants are unsure if they need to solve all parts of the questions presented.
Dough
Well there are actually two questions i need some help with, if you could provide a full solution so i cna see the step by stpe thing it would be nice.
Question 1
A quadratic function f(x) with integral coefficients has the following properties:
f(3/2) = 0, (x-2) is a factor of f(x), and f(4) = 50. Determine f(x).
Question 2
A cubic function g(x) with integral coefficients has the following properties:
g(3) = 0, G(-3/4) = 0, (x+2) is a factor of g(x), g(1) = -84. Determine g(x).
Thanks!
You could begin by writing out a general (generic) quadratic function, e.g. y = ax2 + bx + c and then think how you could solve for a, b and c. Does that help to get you started?
i've written out what I've been given:
f(3/2) = 0 therefore (2x-3) is a factor of f(x),
Factors of f(x) = (2x-3) and (x-2)
f(4) = 50
i also wrote out ax^2 + bx + c as oyu suggested but not seeing a link... :(
whati s the general form of f(x) ??
quadratics look like [itex]f(x) = ax^2 + bx + c[/itex]
ok from taht what is f(2) ?? Using the formula for f(x) above and your given info form equations using f(3/2) and f(4) as well to solve for a, b, and c.
Dough, follow stunner's suggestion. For example, how would you write f(4) in terms of [itex]f(x) = ax^2 + bx + c[/itex]?
i did that but no luck i'll give it another shot, i make mistakes osmetimes so its possible i may have done somethign wrong whihc messed everythign else up...
Go ahead and post here what you've done.
yay, i got the first one... on the third try after the above post, i kept makign silly errors just now... i'll let you know how i do witht he the next one, thanks for the help :D
i don't think i got it right and it was hell of a lot of work... i might give it a shot tomorrow or later i got f(x) = -8x^3 - 50x^2 - 54x + 28
thanks tho i got one so i have the idea now its just not makign stupid mistakes!
dry, we didnt even have to do number 3... i sitll try it agian later caus ei wanan find out how to do it!
By the way, Dough, I think you were doing the first problem in a better way than writing "f(x)= ax2+ bx+ c" as others were telling you. You are correct that since 3/2 is a 0 of f, 2x-3 is a factor. And you are told that x-2 is a factor. Since f is quadratic, the can't be any more factors involving x, only a constant:
f(x)= a(x-2)(2x-3). Now put x=4 in that, set it equal to 50 and solve for a.
Pretty much the same thing with question 2:
You know that 3 and -3/4 are zeroes of g (I presume that "G(-3/4)" was really "g(-3/4)" ) so that x-3 and 4x+3 are factors. You are told that x+ 2 is a factor. Those three factors will give a cubic so there are no other factors with an x. We must have
g(x)= a(x-3)(4x+3)(x+2) for some constant a. Since g(1) = -84, set x= 1, put it equal to -84 and solve for a.
