Taller or shorter than the Empire State Building?
  • Thread starter Thread starter GuMdRop
    Building State
The discussion revolves around a geometry problem comparing the height of a stack of quarters to the Empire State Building. The closet dimensions are 4' x 7' with a height of 8', while the Empire State Building stands at 1250'. The width of a quarter is 1/8" and its diameter is 15/16". To solve the problem, one must calculate the number of quarters needed to reach the building's height and compare it to the number of quarters that can fit in the closet.
  • Understanding of basic geometry concepts
  • Ability to perform unit conversions (inches to feet)
  • Familiarity with volume calculations
  • Knowledge of grid formation and spatial reasoning
  • Calculate the total number of quarters needed to reach 1250' using the height of a quarter.
  • Determine the number of quarters that can fit in the closet based on its dimensions.
  • Visualize the stacking of quarters in a grid formation on the closet floor.
  • Explore similar geometry problems involving volume and height comparisons.
Students in middle school mathematics, educators teaching geometry concepts, and anyone interested in practical applications of volume and height calculations.
GuMdRop
I received this problem in 8th grade goemetry today, and its due tomorrow. i have looked at it for 2 hrs now and STILL can't think of how to figure it out. help PLEASE?
Here it is:
If you filled a closet with stacks of quarters from floor to ceilling and then put all the quarters in one big stack, would it be taller or shorter than the Empire State Building?
Closet Floor=4' x 7' Height=8'
Empire State Building= 1250'
Width of Quarter= 1/8''
Diameter of Quarter= 15/16"
Well you can first determine the # of coins required to stack up to the Empire State Building. You have the overall height and the height (what you call the width... which is incorrect, its actually the height) of a quarter. Figure out how many of those 1/8" are in the 1250' of the building and you will have the # of quarters necessary.
Then visualize putting every quarter down in a grid formation on the closet floor. Using the diameter of the quarter, you can use each dimension of the closet floor to determine how many quarters can be stacked in each of the dimensions. Multiply those 3 dimensions and see if it comes out to more or less then the # of quarters necessary to be taller then the building.
i will try that.
  • · Replies 42 ·
