Error Calculation
by SS2006
Tags: calculation, error
SS2006
SS2006 is offline
#1
Sep21-05, 04:12 PM
P: 84
as good as i am in physics, i just didnt try to understand error calculation
can someone give me 2 easy ways to calculate
error in addition
for example
5 +- 0.2 + 6 +- 0.1
and in mulitplication, like my newest lab
i have f = m tiems g
and the mass is +- 0.2 and gravity is +- 0.1 for example
mas is 25 g lets say, and gravity 9.8
so ya easiest way to calculate error in multi, and additio please :)
thanks
Phys.Org News Partner Science news on Phys.org
Cougars' diverse diet helped them survive the Pleistocene mass extinction
Cyber risks can cause disruption on scale of 2008 crisis, study says
Mantis shrimp stronger than airplanes
Ouabache
Ouabache is offline
#2
Sep21-05, 06:20 PM
Sci Advisor
HW Helper
P: 1,327
This is getting into statistical analysis.....
(i) What are your minimum values in this addition? (hint:[5-0.2]+[6-0.1], add those together) and you get a minimum solution value.
(ii) Similarly what are your maximum values? (add those together) and you get a maximum solution value.
(iii) the sum without including error is just 5+6 = 11
Now,
(a) take the sol'n from (iii) and substract your minimum sol'n.
(b) take your maximum sol'n (from ii) and subtract sol'n from (iii).
In your example, the absolute value of the sol'n in (a) equals the absolute value of sol'n of (b). So the error of your final sum is +/- that value.
For your multiplication question: follow a similar method, multiply minimum values, maximum values and compare to the product of values that did not include your initial errors. So how much did your minimum product differ from the product without including errors? How much did the maximum product differ? You may find these two "differences" are not equal. But you can still make a valid statement about how much +/- error you get in the product.
How much error would you say there is?
SS2006
SS2006 is offline
#3
Sep21-05, 06:46 PM
P: 84
ok, sot he final asnwer would be 11 +- 0.3 ?
how bout mulitplication thats the harde rone i need this b4 tomorrow!
lets say 4 +- 0.2 X 5 +- 0.3
thanks
Ouabache
Ouabache is offline
#4
Sep21-05, 06:50 PM
Sci Advisor
HW Helper
P: 1,327
Error Calculation
Quote Quote by SS2006
You're doing fine !!! Try the same method on multiplication question.
SS2006
SS2006 is offline
#5
Sep21-05, 06:58 PM
P: 84
ok im quite confused bout the mulitplication one
lets say 4 X 4 and 0.2 is the +/- error on both of them, can you just solve that one and show what u did
SS2006
SS2006 is offline
#6
Sep21-05, 07:11 PM
P: 84
hmm is 4 +- 0.2 X 4 +- 0.2
16 +- 1.6?
if it is im aliright, just lemme know
Ouabache
Ouabache is offline
#7
Sep21-05, 07:14 PM
Sci Advisor
HW Helper
P: 1,327
(i) minimum product [4-0.2]*[4-0.2]=14.44
(ii) maximum product [4+0.2]*[4+0.2]= 17.64
(iii) product without error 4*4 = 16
(a) (iii)-minimum 16-14.44 = 1.56
(b) max - (iii) = 17.64-16 = 1.64
Error in product is +/- what? well +/- 1.64 does include the value of your lower error (1.56), but actually overestimates it. If this is experimental data, it is valid to state there is +/- 1.64 (units) error in the result (or 16 +/- 1.64)
Ouabache
Ouabache is offline
#8
Sep21-05, 07:16 PM
Sci Advisor
HW Helper
P: 1,327
16 +- 1.6?
As you can see from my last note, you're sol'n is correct (with one decimal place precision ).
SS2006
SS2006 is offline
#9
Sep21-05, 07:58 PM
P: 84
very much appreciated brother :)
andrevdh
andrevdh is offline
#10
Sep22-05, 03:12 AM
HW Helper
P: 1,449
Error analysis is quite an advance topic. Therefore one usually get the formulae to calculate the error in a value (say Z) as a result of the errors in the values it depends on (say A and B). In the following formulae the errors in the values are indicated by deltas. Firstly the error in a value obtained from a sum or difference calculation are given by:
[tex](\Delta Z)^2=(\Delta A)^2+(\Delta B)^2[/tex]
The error in you first example will therefore be 0.2
In values obtained from multiplication and division calculations one sees the relative error - that is what fraction is the error of the value. The formula for calculating the error in a value obtained from multiplication/division is:
[tex]\left(\frac{\Delta Z}{Z}\right)^2=\left(\frac{\Delta A}{A}\right)^2+\left(\frac{\Delta B}{B}\right)^2[/tex]
If your mass is 25 kg then the resulting force is 245 +/- 3 N.
HallsofIvy
HallsofIvy is offline
#11
Sep22-05, 01:27 PM
Math
Emeritus
Sci Advisor
Thanks
PF Gold
P: 38,898
A perfectly valid way to do this is to add the largest possible value for each and then add the smallest possible value for each.
In this case, one number is 5 +- 0.2 so the largest it could be is 5.02 and the smallest 4.98. The other is 6 +- 0.1 so the largest it could be is 6.1 and the smallest is 5.9. 5.02+ 6.1 is the largest the sum could possibly be and 4.98+ 5.9 is the smallest it could possibly be. Take the midpoint of those two numbers and calculate the possible errror from those.
Of course, what andrevdh suggested will give you (approximately) the same answer. It's an old engineer's "rule of thumb"- "when adding two measurements, the errors add; when multiplying two measurements, the relative errors add".
Register to reply
Related Discussions
error calculation Introductory Physics Homework 3
Some error calculation help Advanced Physics Homework 3
Calculation Error? Introductory Physics Homework 3
Error calculation General Math 1
