Momentum Problem and final velocities
  • Thread starter Thread starter Foon
    Final Momentum
The discussion focuses on solving a momentum problem involving two balls of equal mass colliding, where one ball is initially stationary. The initial speed of the moving ball is 2.25 m/s, and the angles after the collision are 31.1 degrees and 48.9 degrees. The conservation of momentum equations are established, leading to the formula v2 = (2.25 - v3*cos(48.9)) / cos(31.1) for calculating the final velocities of the balls post-collision.
  • Understanding of conservation of momentum principles
  • Basic trigonometry for resolving vectors into components
  • Familiarity with algebraic manipulation of equations
  • Knowledge of physics concepts related to collisions
  • Study the law of conservation of momentum in detail
  • Learn how to resolve vectors into their x and y components
  • Practice solving collision problems using different mass and velocity scenarios
  • Explore the effects of angles on post-collision velocities in elastic and inelastic collisions
Students studying physics, particularly those focusing on mechanics and collision problems, as well as educators looking for practical examples of momentum conservation.
Foon
I've been hacking away at this question for a while but I'm really getting nowhere. All I know is that its supposed to be broken down into components or something. Any helps would be appreciated.
Question:
Two balls of equal mass (m) undergo a collision. One ball is initially stationary. after the collision, the velocities of the balls make angles of 31.1 degrees and 48.9 degrees relative to the original direction of motion of the moving ball. (momentum is conserved)
b) If the initial speed of the moving ball is 2.25 m/s what are the speeds of the balls after the collision?
I'm pretty sure that we're searching for the final velocties. Again, any help would be great. :smile:
Thanks!
You said it yourself, momentum is conserved. So write the conservation of momentum equations for each component. Hint: choose your coordinate system so that one axis lies along the initial direction of the moving mass.
First of all, don't worry if you're struggling with this problem. Momentum problems can be tricky, but with some practice and understanding of the concepts, you'll be able to solve them easily.
To solve this problem, you'll need to use the law of conservation of momentum, which states that in a closed system, the total momentum before a collision is equal to the total momentum after the collision. In this case, the two balls are the only objects involved in the collision, so we can apply this law to them.
To break down the problem into components, we'll use trigonometry. The initial velocity of the moving ball can be represented as v1, and the final velocities of the two balls can be represented as v2 and v3. We can also break down the velocities into their x and y components, using the angles given in the question.
Using the law of conservation of momentum, we can write the following equation:
m*v1 = m*v2*cos(31.1) + m*v3*cos(48.9)
Since the masses of the two balls are equal, we can cancel them out from both sides of the equation. This leaves us with:
v1 = v2*cos(31.1) + v3*cos(48.9)
We also know that the initial velocity of the moving ball is 2.25 m/s, so we can substitute this value into the equation. This gives us:
2.25 = v2*cos(31.1) + v3*cos(48.9)
Now, we can solve for the final velocities by using basic algebra. First, we'll isolate v2 by subtracting v3*cos(48.9) from both sides of the equation. This gives us:
2.25 - v3*cos(48.9) = v2*cos(31.1)
Next, we'll divide both sides of the equation by cos(31.1) to isolate v2. This gives us:
(2.25 - v3*cos(48.9)) / cos(31.1) = v2
Finally, we can plug in the values for the given angles and solve for v2:
Now, we can use the same process to solve for v3. We'll
  • · Replies 19 ·
