What does the frequency of a photon actually mean?
  • Context: Undergrad
  • Thread starter Thread starter Agnostic
    Frequency Mean Photon
The discussion centers on the meaning of the frequency of a photon, exploring its implications in quantum mechanics, wave-particle duality, and the relationship between frequency, wavelength, and energy. Participants examine both theoretical and conceptual aspects of photons in free space.
  • One participant questions what the frequency of a photon represents in terms of its behavior over time.
  • Another participant discusses the concept of a photon not having a definite shape or boundary, emphasizing its nature as a clump of energy rather than a classical particle.
  • It is noted that a photon has a well-defined wavelength only in a momentum eigenstate, but this state is never fully realized, leading to uncertainty in position.
  • The uncertainty in position is suggested to be proportional to the wavelength, which some participants argue could be interpreted as the "size" of the photon.
  • One participant mentions that electromagnetic waves can be described by the relationship between speed, wavelength, and frequency, particularly when transitioning between different media.
  • There is a contention regarding the invariance of frequency when light travels from one medium to another, with one participant asserting that frequency is invariant due to conservation of energy.
Participants express differing views on the invariance of frequency and the implications of wavelength in defining the "size" of a photon. The discussion remains unresolved regarding the exact nature of frequency and its relationship to other properties of photons.
Participants acknowledge the uncertainty in defining the size of a photon and the implications of wave-particle duality, but do not reach a consensus on these points.
Agnostic
Say you have one photon traveling through free space.
It has its energy level with its corresponding wavelength and frequency.
What does the frequency mean? What is it doing x amount of times per second?
Also, the same goes for the wavelength.
marlon said:
WHAT IS THE DIMENSION OF A PHOTON ?
You all know that QM provides us with 1 (and not two) way of describing physical processes : particle wave duality. We apply our classical ideas of what "wave" is, and what a "particle" is. A particle, like a grain of sand, has a definite boundary in space, i.e. a grain of sand doesn't appear spread out that it's exact shape and boundary are vague. Thus, it has what we classically define as a particle. A wave, on the other hand, can spread out over space.
Now, here is the clue : A photon description in QM is NOT defined as having an exact shape and boundary in space, thus a photon is NO classical particle. It is defined as clumps of energy. So in energy coordinates, it has definite "points", but it has no definite "size" in real space! So when talking about 'size' of a photon you must realize that we work in energy space (more formally we work with momentum-eigenstates)
Having said that, the most common explanation for the "wave-particle duality" is that light behaves as waves in experiments such as the double slit, and behaves as particles when we do things like the photoelectric effect
A photon has a perfectly well-defined wavelength only when it's in a momentum eigenstate, i.e. when it has a perfectly well-defined momentum (and energy). This never happens. A photon is always in a superposition of momentum eigenstates:
The only quantity that we might want to call the "size" of the photon is the width of the Fourier transform of the momentum-space wave function, f, i.e. the uncertainty in the photon's position. This uncertainty could be anything between zero and infinity. (I'm ignoring Planck-scale effects here). Since it can be arbitrarily close to zero, it makes sense to call the photon a "point particle".
However, if we assume that the uncertainty in momentum is proportional to the magnitude of the momentum (which is the only thing we can assume if we know nothing about the state), the uncertainty in position is proportional to Planck's constant divided by p (the magnitude of the momentum). Since p is inversely proportional to the wavelength, the uncertainty in position is proportional to the wavelength.
So it makes sense to think of the wavelength as the "size" of the photon (or at least as something proportional to it). This may seem strange, but it is at least consistent with e.g. the fact that microwaves (with wavelengths of order 1 cm) won't go through a metal net with millimeter-sized holes (like the net that covers the window of your microwave oven), but they will go through a net with much larger holes.
Electromagnetic waves moving through a vacuum, when v = c, can be described as velocity=speed of light/wavelength.
When light travel from one medium to another, frequency remains more or less the same, but wavelength and/or speed changes.
Awesome, that was sort of what I was thinking. Thanks for the clarification.
More or less? Frequency is most certainly invariant, conservation of energy makes this so :wink: .
Claude Bile said:
:wink: .
It's ok, I'm not interested.
  • · Replies 21 ·
  • · Replies 18 ·
12K
