How Do I Use Taylor Polynomials for Approximation and Error Estimation?
  • Thread starter Thread starter Benny
    Error
This discussion focuses on using Taylor polynomials for approximating functions and estimating errors. Specifically, it addresses approximating e^(1/2) to four decimal places using the Taylor series expansion and determining the values of x for which sqrt(1+x) can be replaced by 1 + (x/2) with an error less than 0.01. The Taylor series for e^x is utilized, and the remainder equation R_n is applied to both problems to ensure the approximations meet the specified accuracy requirements.
  • Understanding of Taylor series and polynomial approximations
  • Familiarity with the remainder theorem in Taylor series
  • Basic knowledge of calculus, particularly derivatives
  • Ability to perform calculations involving factorials and series summation
  • Learn how to derive Taylor series for common functions, such as e^x and sqrt(x)
  • Study the application of the remainder theorem in error estimation
  • Explore numerical methods for approximating functions to specified decimal places
  • Investigate convergence criteria for Taylor series expansions
Students and educators in calculus, mathematicians focusing on approximation methods, and anyone interested in numerical analysis and error estimation techniques.
Benny
I'm not understanding questions where I need to determines values of x for which one function can be replaced by another with a specified maximum allowable error. I'm also having trouble trying to approximate a number to a specified number of decimal places. Here are two questions that I would like some help with.
1. Use Taylor polynomials to approximate the given number to four decimal places. (You may assume that 2 < e < 3)
e^(1/2) is the number.
2. For what values of x can we replace sqrt(1+x) by 1 + (x/2) with an error of less than 0.01?
1. If I recall correctly then [tex]e^x = \sum\limits_{n = 0}^\infty {\frac{{x^n }}{{n!}}} \Rightarrow e^{\frac{1}{2}} = \sum\limits_{n = 0}^\infty {\frac{1}{{n!}}} \left( {\frac{1}{2}} \right)^n[/tex].
Just to give myself an idea of the numbers I'm working with I used a calculator to obtain e^(1/2) = 1.648721271.
So I need to find a value of n which will give me a number which is within 4 decimal places of e^(1/2).
I have the remainder equation [tex]R_n = \frac{{f^{\left( {n + 1} \right)} \left( c \right)}}{{\left( {n + 1} \right)!}}\left( {x - a} \right)^{n + 1}[/tex] for some c between x and a.
I'm not sure how to apply it to this question. I think question 2 requires the same thing but again I'm not sure how to apply the remainder equation. Can someone please help me out?
1. For your first question, you can use the Taylor polynomial to approximate e^(1/2). You can start by writing out the Taylor series for e^x: e^x = \sum_{n=0}^{\infty}\frac{x^n}{n!}Now substitute x = 1/2 into this equation and you have your Taylor polynomial approximation of e^(1/2). To get the value to four decimal places, you need to take the sum up to n = 4, which gives you an approximate value of 1.6487.2. For the second question, you need to use the remainder equation to determine the values of x for which the replacement is valid. The remainder equation is given by: R_n = \frac{f^{(n+1)}(c)}{(n+1)!}(x-a)^{n+1} where f(x) is the original function (in this case, sqrt(1+x)), c is a point between x and a (in this case, a = 0, since sqrt(1) = 1), and n is the order of the Taylor polynomial. To determine the values of x for which this replacement is valid, you need to find an n such that R_n < 0.01. To do this, you can set R_n = 0.01 and solve for n. This will give you the maximum allowable error of 0.01.
  • · Replies 25 ·
  • · Replies 21 ·
  • · Replies 17 ·
