Confusing arken/weber problem (del in triple vector product)
The discussion revolves around a problem from the Arfken/Weber textbook concerning vector calculus, specifically the verification of the identity involving the cross product of a vector field and the curl of itself. Participants are exploring the nuances of the mathematical expression and the origin of the factor of 1/2 in the equation.
  • Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss the use of the BAC-CAB rule and index-based calculations to understand the identity. Some question the application of vector identities and the implications of the del operator acting on the vector fields. Others explore alternative methods to derive the identity.
The conversation is ongoing, with some participants providing insights and alternative approaches. There is a recognition of the complexities involved in applying vector identities correctly, and while some clarity has been achieved, not all participants express full understanding.
Participants note the challenge of understanding the factor of 1/2 and the specific roles of the vectors involved in the identity. There is mention of constraints related to the assumptions made about the vectors and their interactions.
Brad Barker
the following problem is in the arfken/weber textbook and was also on a practice exam for my mathematical methods course:
Verify that
[tex] \mathbf{A} \times (\nabla \times \mathbf{A}) = \frac{1}{2} \nabla(A^2) - (\mathbf{A} \cdot \nabla)\mathbf{A}.[/tex]
i used the BAC-CAB rule, but i don't get the factor of 1/2.
the solutions booklet that came with the textbook very tersely explains, "the factor of 1/2 occurs because the del only operates on one of the A's."
i would very much appreciate an explanation that is perhaps more informative than this one sentence blurb! :-p
thank you.
I think the "product rule" was used.
Have you tried an index-based calculation...
[tex]\epsilon_{ijk}A^j\epsilon^{klm}\nabla_l A_m<br /> =\left( \delta_i^l\delta_j^m- \delta_i^m\delta_j^l)A^j\nabla_l A_m[/tex]
You can't just go around baccabing things. In particular as the one sentence you dislike states the del only operates on one of the A's. That other half is busy over here
[tex](\mathbf{A} \times \nabla) \times \mathbf{A}= \frac{1}{2} \nabla(A^2) - \mathbf{A}(\nabla\cdot\mathbf{A})[/tex]
since
[tex](a\times\nabla)\times b+a\nabla\cdot b=a\times(\nabla\times b)+(a\cdot\nabla)b[/tex]
what is
[tex]\nabla(A^2)[/tex]
If one A is constant?
say A(x) then find
[tex]\nabla(A(x).A(0))|_{x=0}[/tex]
Compare the 1-var analog
D[y(x)*y(x)]|{x=0}=2y(0)*y'(0)
D[y(0)*y(x)]|{x=0}=y(0)*y'(0)
since
i still don't understand.
It is like asking where the 1/2 comes from in
[tex]y \ \frac{d}{dx}y=\frac{1}{2} \ \frac{d}{dx}y^2[/tex]
You should avoid trying to use vector identities on del that do not apply.
[tex]\mathbf{A_1} \times (\nabla_2 \times \mathbf{A_2}) =\nabla_2(\mathbf{A_1}\cdot\mathbf{A_2}) - (\mathbf{A_1} \cdot \nabla_2)\mathbf{A_2}[/tex]
is true and makes what is happening clear. A1 and A2 are equal, but nabla2 acts only on A2. The grad(A^2) part is the place where the distinction matters. In order to switch back to more standard notation we note that
[tex]\nabla_1(\mathbf{A_1}\cdot\mathbf{A_2})=\nabla_2(\mathbf{A_1}\cdot\mathbf{A_2})[/tex]
and
[tex]\nabla(\mathbf{A}\cdot\mathbf{A})=\nabla_1(\mathbf{A_1}\cdot\mathbf{A_2})+\nabla_2(\mathbf{A_1}\cdot\mathbf{A_2})[/tex]
You infact did not use B(A.C)-C(A.B), you used B(A.C)-(A.B)C
so you saw that not all vector idenetities hold if a vector is replaced by del, but you still used an identity that was not true.
for comparison
[tex](\mathbf{A_1} \times \nabla_2) \times \mathbf{A_2} =\nabla_2(\mathbf{A_1}\cdot\mathbf{A_2}) - \mathbf{A_1}(\nabla_2\cdot\mathbf{A_2})[/tex]
thus
and
for comparison
thus
ah!
thank you very much. that is exactly what i needed.
thanks a lot.
found another way to do the problem (without invoking the scary kronecker deltas and epsilon tensors!). this is the proof suggested by david griffiths' intro to electrodynamics:
[tex] \nabla (\mathbf{A} \cdot \mathbf{B}) = \mathbf{A} \times (\nabla \times \mathbf{B}) + \mathbf{B} \times (\nabla \times \mathbf{A}) + (\mathbf{A} \cdot \nabla)\mathbf{B} + (\mathbf{B} \cdot \nabla)\mathbf{A}.[/tex]
when [tex]\mathbf{A} = \mathbf{B},[/tex]
[tex]\nabla (\mathbf{A} \cdot \mathbf{A}) = 2\mathbf{A} \times (\nabla \times \mathbf{A}) + 2(\mathbf{A} \cdot \nabla)\mathbf{A}.[/tex]
note: [tex]\mathbf{A} \cdot \mathbf{A} = A^2.[/tex]
so
[tex]\mathbf{A} \times (\nabla \times \mathbf{A}) = \frac{1}{2} \nabla(A^2) - (\mathbf{A} \cdot \nabla)\mathbf{A}.[/tex]
Of course, someone had to derive [or give you] this first identity of the gradient of a dot-product in terms of the cross-products of curls... or is this identity just so intuitively obvious?
Believe it or not, the epsilon and delta tensors make these "Vector Calculus identities" much simpler... with some practice. It's not unlike learning Euler's identity in complex algebra to make "Trigonometric identities" much simpler.
  • · Replies 18 ·
